| sectional work barge design We need some help to design for 2 sectional barges, something like you see at http://www.bargesystems.com/pictures.htm Each section would be 40 ft. long and 8 ft. wide. The 2 sections would be united by a bridge, making the platform as wide as possible but at least 3 ft. wider. Ideally, the sections would be united by removable beams that get inserted in each section and then locked into place. To make it even more rigid, 3 overhead frames would be placed at very end and center of the barges (say 19 wide, 10 ft. high) that would also serve as a light roof support (we're in Panama: either it rains or the sun is shining like crazy). Ideally, those frames simply have to be put into existing 'holes' with a very simple locking device. A The load capacity of the total platform doesn't have to be more than about 30.000 lbs. It will only be used on inland waters. A support structure for an outboard is also required. Part of the section would house a diesel tank (2x 250 gal. or so); one a fresh water tank (also 2x 250 gal.); we'll need area a little bit reinforced to accommodate a 25 KW genset.... And maybe a very simple ramp on the side What would be best: steel or alum? I understand alum. doesn't corrode but you need more of it to give the same strengh and a few sacrificial anodes on a steel construction should help too. The design would have to include the files so a CNC machine can cut all the required pieces and they only have to weld things together here in Panama. Thorwald
__________________ ----------------------------------------- www.expeditionyacht.org The ultimate expedition yacht conversion |
| How will you move the barge? I am a Naval architect and can provide the design of a barge 40 ft x 8ft size. Steel is the best material. You provide anodes and paint well, it will last 20 years and more..... Also give me the email ID |
| It depends what is available locally for repairs. This will probably dictate more than any other 'technical' requirement. I suspect steel is common throughout your part of the world? But for that size, transportability is a big factor...ie weight! |
| My idea was to add a structure at the rear of each barge to attach an outboard engine. Steel is most common here and practical, probably cheaper too but yes, weight is an issue.
| Work Barge | CMARSHALL | Boat Design | 2 | 08-19-2005 07:32 AM |
| interior design work experience/work wanted | schwing | Services & Employment | 1 | 01-19-2005 12:52 AM |
| Sectional area curve ? | fcfc | Boat Design | 7 | 01-07-2005 01:52 PM |
| Barge Design | K Spears | Boat Design | 4 | 01-26-2004 11:39 PM |
| barge design | Boat Design | 0 | 02-09-2002 12:23 PM | |
