Old 05-08-2006, 05:12 PM
german german is offline
rivet counter
Rep: 10 Posts: 7
seawater jacuzzi onboard
Hi all!!!
We have to install 4 jacuzzi bathtubs on a tourism vessel. All 4 tubs are exposed on the weather deck and all the system must work with seawater. We already have a boiler for the hotwater supply of the 4 systems and we are having a real bad time looking for the heaters of each bathtub. They must be electric and all the suppliers that we have talked to do not have anything that can be used with seawater. i know that there is more than a few of this jacuzzi systems installed on several yachts but i've been unable to get any information regarding suppliers of the bathtubs, recirculating seawater heaters or pumps that use hot seawater and which are installed on those yachts.
does any of you have any idea on who can supply these items?
any info is really appreciated.
cheers
german
Old 05-08-2006, 09:31 PM
SheetWise's Avatar
SheetWise SheetWise is offline
All Beach -- No Water.
Rep: 525 Posts: 243
Electric? Why not a heat exchanger with the engine ...
Did you mean you're looking for the blowers or jets?
Old 05-09-2006, 08:09 AM
rivet counter
Rep: 10 Posts: 7
the electric heater is only to maintain the temperature of the water as it recirculates, for the hot water supply of the tubs we have a boiler.
the tub is not the problem, acrylic or fiberglass is the same, the pump must be seaworthy and also is not a problem but the thing is that electric heater. no supplier that we are aware of have a seawater electric heater of the type we need.
cheers
german
Old 05-09-2006, 09:06 AM
SheetWise's Avatar
Rep: 525 Posts: 243
As long as you have a seawater pump and circuit, it doesn't matter what type of a heater you use -- just add a heat exchanger.
Old 05-13-2006, 12:13 PM
Richard Hillsid Richard Hillsid is offline
Rep: 19 Posts: 117
Yep and well make you the stainless steel tub, even made one of aluminium last year.
Which Jacuzzi to install in my Boat? the big jetski Propulsion 4 12-14-2005 04:46 AM
FOR SALE: Jacuzzi 12WJ Bowl Outboard jfsproducts Marketplace 1 03-25-2002 10:17 PM
