| Seahull 3.9m New 1012 Model Catamaran, Trihull Multi Hull Boats New 2011 ![]() Please check this out new seahull boat mould was produced from sep in 2010 and so far 3 boats come off the mould first one was May 2011 took 8 months to get a second one, then got two off a million dollar oven and was the green and black one, starting to look good, will make a hydrofoil for it shortly, rides on the centre keel like a water ski, heres a link to see a video, its a lod yamaha two stroke 30hp, http://www.youtube.com/watch?v=q1VMn...TJHBRjIcRCKB-y it also planned with 5 adults and 5 kids on board, we looking for interested dealers around the world that might want it in the lineup and will be trying to get it to as many shows in world this year as we can, Proudly made by Stephen Snedden, Copyright 2010-2012 Last edited by foilcats : 01-12-2012 at 02:54 AM. |
| www.seahull.com is the website, its a hit the responce so far is all thumbs up, |
| Seahull 3.9m New 2012 Model Catamaran, Trihull Multi Hull Boats New 2011 |
| Are the hulls foam filled, sealed air space, or open? |
| Foam Filled can be foam filled if wanted, as a standard i offer foam under floor in the cavitys, so it will only submerge, the deck os free draining and hand have acess to the inside of hulls to bilge it by hand bilge pump or place small 12v pump, if you want to fill it with the foam during molding process maybe can cut weight of hull down to around 150kg, as it strengthens the hull with the inner foam, theres alsorts of configerations it all costs and needs time to sort it, the materials we use is the UV proof ones that the best water tanks are made of, doing a karaka green one for a customer next week hes putting a 40hp etech on it as it is tiller but has E start and motor trim on tiller handle, also will be doing a 3m and 5.5m model this year |
| Heavy? I know this has been a major downfall with plastic boats before Quote:
| Also can seal air space if wanted, as standard its got some holes into it for rods |
we can sharpen the price a little, my problem im not the manufacture, just own the mould, |
| Are your boats also made from Roplene or another polymer? |
| other polymers I am learning as we go, i see alot of options and are looking for consultancy in this area, will make it from what ever is specified by the buyer if the raw materials are in hand and if the manufacture agrees they can do it sucessfully |
| Seahull boat test I watched the you tube video on this little boat and it looks impressive,seems to get along ok. I wonder how it go's in rough water. ![]() |
@ 200kg its 100% + heavier than a tinny 3.85 Vnosed punt = 92kg 4.1 = 114kg http://www.seajayboats.com.au/models/v-nose-punt/nomad |
| 114 sounds a little lighter, I like the faithful tinny, but you are right the plastic boats have had a problem with weight in the past,even a small 1 man kayack is 20+ kilo's. |
| Transat 2011: Multi vs Mono | Doug Lord | Multihulls | 14 | 07-11-2011 03:28 PM |
| model solar boats - hull design | woodyp | Boat Design | 28 | 09-21-2010 03:36 PM |
| Multi Hull Aluminum Catamaran Plans | Fiddleback | Metal Boat Building | 3 | 04-19-2006 07:55 AM |
| Multi Hull boats | J. Olson | Boatbuilding | 5 | 08-28-2004 07:40 AM |
| Multi-Hull Boats | J. Olson | Powerboats | 2 | 08-05-2001 04:15 PM |
