  #31
Old 01-13-2012, 03:30 AM
foilcats foilcats is offline
Stephen Snedden
Rep: 16 Posts: 53
http://www.youtube.com/watch?v=oVrcD...nFn99uSdvP8fY5
  #32
Old 01-13-2012, 03:32 AM
Stephen Snedden
Rep: 16 Posts: 53
http://youtu.be/-zMhbWwGX10
  #33
Old 01-13-2012, 04:10 AM
harry cassin's Avatar
harry cassin harry cassin is offline
Old Salt
Rep: 28 Posts: 48
Iv'e also seen 100,000 watt go carts that are just balistic,
http://www.allcatamarans.com/
Go Catamarans
  #34
Old 01-13-2012, 05:43 AM
sabahcat's Avatar
sabahcat sabahcat is offline
Rep: 257 Posts: 793
Originally Posted by foilcats View Post
Its preferable at sea to have abit of weight also the boats you are comparing me with a mono hulls and not apples with apples,
Well I did compare a 4.1m tinny to the 3.9m cat
cats beam is 110mm wider, but tinny is 200mm longer
cat is 500mm high tinny is 880mm high
I'm reckon thats a pretty fair comparison
  #35
Old 01-13-2012, 06:05 AM
sabahcat's Avatar
Rep: 257 Posts: 793
heres a couple problems with the Tinnys, hard rideing and unstable, most likely a wet ride,
I have had tinnies that were very stable and dry and gave a fairly soft ride
I have also had a pioneer plastic dinghy that was as tippy as buggery
noisy, cold to touch, easily damage, no flat deck, low sides,
The outboard running is noisier
Cold to touch in QLD? it was 37 degrees yesterday
easily damaged? Damned near indestructible more like it
They can have flat decks and in the last post I showed the sides were considerably higher than the cat
cant use them in flood get electrocuted,
Better tell these SES guys during the floods here recently
Most of the rescue services, police etc use them
The cat can handle the surf, wouldnt go near it in that tinny boat,
Seems these tinnys can handle it OK
http://www.surfrescue.com.au/main/li...-rescue-boats/
But more importantly, why would I want to?
It would still be dangerous and unseamanlike in a 3.8m plastic cat
i was building alloy boats and the cat we made was similar weight out of 2mm alloy, out of 3mm it was heavier,
amazing, a heavier built dinghy was well...........heavier
Look, I have nothing against it, plastic boats are good for some but not for me
and I would prefer a cat
But I need strong, light and affordable for a tender and plastic boats, like solid fiberglass boats in that size just don't get close.
Now if you could do one in nidaplast or foam core for about $1500 $2000 you'd have a sale.
  #36
Old 01-13-2012, 06:11 AM
Old Salt
Rep: 28 Posts: 48
Clear Images... I remember the floods and the stupid people who let the dam get to 180%
Before releasing a mountain size wave in one go. Grrr
Go Catamarans
  #37
Old 01-13-2012, 01:29 PM
Stephen Snedden
Rep: 16 Posts: 53
EVEN THOUGH THE TINNY IS ALITTLE LONGER THE USABLE DECK AREA IS ALOT LESS THAN THE CAT,
ACTUALLY THE CAT ARE TOTAL HEIGHT OF 900MM, TINNY 880 HIGH, MUST BE TO BOTTOM OF HULL NOT OFF THE FLOOR,
THAT SURF BOAT WASNT 4M LONG,
IVE JUST HAD A GUTS FULL OF TINNIES,
SEAHULL HAS ALREADY PROVED ITSELF TO BE A GOOD BOAT,
YET TO SEE A SAME SIZE TINNY THAT CAN COMPARE TO IT,
GOOD LUCK WITH FINDING YOUR BOAT AT THAT PRICE, COST MORE THAN THAT AT PRESENT, WORKING ON GETTING A OVEN WHICH MAYBE CAN REDUCE MANUFACTURING COST ALOT,
  #38
Old 01-13-2012, 01:42 PM
Stephen Snedden
Rep: 16 Posts: 53
MUST OF BEEN A MONO HULL,
They can have flat decks and in the last post I showed the sides were considerably higher than the cat,
BETTER YOU BUY YOUR SELF A TINNY, FOR A TENDER BOAT MAYBE SUIT YOU BETTER,
TRY POLYCRAFT THEY HAVE A 3M BOAT AROUND 70KG ITS THE FOAM FILLED MAYBE SUIT YOU,
  #39
Old 01-13-2012, 02:09 PM
Stephen Snedden
Rep: 16 Posts: 53
LOOKING BACK TO OUR CHAT IN 2008 I SEE YOU SUGGESTED THE webster TWINFISHER AND POLYCRAFT, IM WORKING ON 2 MORE MOULDS NOW, WILL DO A 3.2M AND A 5.7M NEXT, THE 3.2M MAYBE SUITS YOU,
  #40
Old 01-13-2012, 04:00 PM
Old Salt
Rep: 28 Posts: 48
Seahull with a Seagull
Seahull with a Seagull... bring back the old seagull classic motor
Go Catamarans
  #41
Old 01-14-2012, 03:37 PM
Stephen Snedden
Rep: 16 Posts: 53
we got the seagull race on waikato river each year, selva in europe do full rebuilds on the seagulls still, considered using seagull as a brand on there new outboards i have, easy to remember seahull being close to seagull, this was my intension
  #42
Old 01-14-2012, 04:12 PM
beachcraft beachcraft is offline
Rep: 15 Posts: 40
can be foam filled if wanted, as a standard i offer foam under floor in the cavitys, so it will only submerge, the deck os free draining and hand have acess to the inside of hulls to bilge it by hand bilge pump or place small 12v pump, if you want to fill it with the foam during molding process maybe can cut weight of hull down to around 150kg, as it strengthens the hull with the inner foam, theres alsorts of configerations it all costs and needs time to sort it, the materials we use is the UV proof ones that the best water tanks are made of, doing a karaka green one for a customer next week hes putting a 40hp etech on it as it is tiller but has E start and motor trim on tiller handle, also will be doing a 3m and 5.5m model this year
Thanks.
Do you have a weight estimate on the 3m?
It would be good to have a small model that is light enough to easily pull out of the water and clear of the waves on the beach.
  #43
Old 01-14-2012, 04:25 PM
Old Salt
Rep: 28 Posts: 48
The seagull was a fantastic motor Foilcat and still is for people that have them, so simple to rebuild
Go Catamarans
Transat 2011: Multi vs Mono Doug Lord Multihulls 14 07-11-2011 03:28 PM
model solar boats - hull design woodyp Boat Design 28 09-21-2010 03:36 PM
Multi Hull Aluminum Catamaran Plans Fiddleback Metal Boat Building 3 04-19-2006 07:55 AM
Multi Hull boats J. Olson Boatbuilding 5 08-28-2004 07:40 AM
Multi-Hull Boats J. Olson Powerboats 2 08-05-2001 04:15 PM
