Old 06-19-2003, 12:11 PM
kudu kudu is offline
Rep: 10 Posts: 112
Seacock manifold system
Is it possible to install a manifold seacock system instead of drilling numerous holes into a newly constructed hull? The side benefit would be in an emergency I would only have to shut one main valve off instead of several small ones throughout the boat.
Old 06-19-2003, 02:22 PM
Rep: 1397 Posts: 7,215
Yes. The main seacock has to be able to handle the flow. Sea chests are a common design.
Old 06-19-2003, 05:53 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 637 Posts: 1,720
Look at the rec.boats.building newsgroup - there is a current thread on sea-chests.
Steve
Old 06-19-2003, 08:22 PM
Rep: 10 Posts: 112
Steve, This may sound lame but where can I find the newgroup rec.boats.building you speak of? Is it located in boatdesign.net or maybe Google?
Old 06-19-2003, 09:11 PM
SailDesign's Avatar
kudu - you can do a group search in google - just hit the "Groups" tab and do an advanced search on "rec.boats.building", search for "seachest" during the last month or so.
Good luck - let me know if you have problems.
Steve
Old 06-20-2003, 06:30 PM
Rep: 10 Posts: 112
Does anyone have any photographs or drawings of a sea chest type system that they could share?
Old 06-20-2003, 07:12 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
Cant find my drawings, but basically for my 47fter I was looking at about a 2" pipe coming up above the water line with a shut off at the bottom. and an inspection hatch at the top for cleaning and antifouling. Then individual pipes with valves coming off the central pipe. Much better than lots of holes. I have been in a situation where that set up prevented a (big) yacht from sinking.
Most of the big yachts (35m+) that I have worked on have a compressed air feed to the sea chest, then if anything gets sucked into it you just open the air valve and blow it out!
Paul
Old 06-20-2003, 07:29 PM
Rep: 10 Posts: 112
Thanks for the reply...Could the same result be obtained from a backflush system similar to one found on a swimming pool. Where an electric motor turns a pump that flushes water (controled by a multi-ported valve) in the reverse flow from normal, to clean the filter system?
Old 06-20-2003, 07:38 PM
Rep: 10 Posts: 112
I agree with you on the safety feature of the sea chest...It is beyond me why builders go through the all trouble of building a fine hull then drill several holes in it..!!!
Old 06-21-2003, 10:20 PM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
The June 2003 edition of "PassageMaker" magazine has an article on DeFever yachts that features a photograph of the sea chest in the engine room that most Defever's are fitted with. One of the features of their installation that I like a lot is that the sea chest extends above the LWL and is fitted with a gasketted bolt-on clear cover so that checking for and clearing debris in the intakes is easily done.
Old 06-22-2003, 03:28 PM
Rep: 10 Posts: 112
Is there a screen or some other device that would catch debris before exiting the sea chest? Also, how would you measure the required volume/diameter of the sea chest needed?
Old 06-22-2003, 11:30 PM
You can install screens. Also, there is a grill on the outside. To figure out the diameter, add all the areas of all the supply pipes.
Old 06-24-2003, 12:20 AM
Raykenn Raykenn is offline
Member
Rep: 10 Posts: 23
Seachest
Kudo,
Just wanted to pass along a recent mistake I observed in a seachest installation. The vessel though relatively small (40') is intended for commercial/quasi-military operation. I will not name the manufacturer other than they are from the U.S..
There were two immediate problems:
1. Because the engine space is cramped, the location of the seachest did not allow reasonable access for cleaning, service, etc., but it was close enough to the engine to act as a step!
2. This was the second problem. The manufacturer ran a plastic pipe ( approximately 1" dia) straight into the seachest. There was no valve between the pipe and the seachest connection. Within one week of delivery, a local swabbie stepped on the pipe using it to climb over the back of the engine, snapping it off, and creating an uncontrollable flooding situation. (He was immediately elected to stick his finger in the hole until a proper plug could be located)
While a steel seachest and piping is obviously more abuse resistant, I realize that this is not always possible. At minimum I recommend the installation of an isolation valve immediately between the seachest and each piping connection.
Regards
Ray
Old 06-25-2003, 12:27 PM
Rep: 10 Posts: 112
AMEN Raykenn!! My thought was to place a valve between every outgoing pipe leaving the seachest. Not sure if this is "over kill" but it does give you the luxury of isolating an entire section for servicing.
Old 06-25-2003, 12:46 PM
I find it easier to install a master seacock. Instead of drilling holes and using several trough-hull fittings, you have a single through-hull. Another advantage is that the main seacock has a threaded out, so it is possible to just screw on pipes, adaptors, reducers or anything else you need.
Why install a Wet Manifold? rjohnbriggs DIY Marinizing 19 08-30-2005 12:39 PM
Autopilot System for Sailboat taobsu Boat Design 0 08-09-2005 01:41 PM
Another new propulsion system DEDave Boatbuilding 12 09-09-2004 11:25 PM
geometry of sailing Sailboats 8 10-12-2002 11:58 AM
Yachtica Integrated Systems yachtica Materials 0 03-28-2002 08:34 AM
