Old 04-16-2005, 04:46 AM
trimix trimix is offline
Rep: 10 Posts: 35
Schedule of conditions for a new project
I request your suggestions in order to write a schedule of conditions for a new project. My goal is to write a request for proposal in order to consult some designers. I want it to be as precise as it must be to reflect my thoughts. Obviously the designer will comment it and modify some points !
Another goal is to forget nothing.
Thanks for your help
Mik
Old 04-16-2005, 04:48 AM
yokebutt yokebutt is offline
Boatbuilder
Rep: 15 Posts: 545
Yokebutt.
Old 04-16-2005, 05:47 AM
Willallison's Avatar
Rep: 2319 Posts: 3,502
I think what Yokebutt is trying to say is that we'' need a bit more information in order to try to help you...
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 04-16-2005, 06:19 AM
Rep: 10 Posts: 35
What I want to do is to write all informations necessary to a naval designer to understand what will be my boat project. For example, the type of boat (motor or sail...) the dimensions, the program and so on...
Mik
Old 04-16-2005, 12:00 PM
Zewe Zewe is offline
Rep: 10 Posts: 12
Suggested outline
If I understand you correctly, you are asking for suggestions regarding the items that should be included in a comprehensive request that will be submitted to a boat designer.
I would organize a request under four headings:
1) General description, 25 words or less the get you in the ballpark.
2) Primary usage expected for the boat.
3) Top priorities: a list of specific attributes that you really believe that the boat must have in order to satisfy you. This list may include minimum cruising speed, maximum length, must be trailerable, etc. The top priorities should only include items that you believe the boat must satisfy in order to keep you motivated to pursue the project.
4) Other goals: a list of wants that are not absolute needs.
Perhaps you can respond with this much info, and others on the list can suggest items that require further consideration.
Randy
Old 04-16-2005, 04:04 PM
Sean Herron's Avatar
Sean Herron Sean Herron is offline
Rep: 405 Posts: 1,532
Shopping carts with rubber wheels...
Hello...
If you take those hard wheels off their mounts and weld or bolt on some pnuematics - there may be a lesser problem of getting pissed on from a third story window from people who have to get up at 5 AM...
Cheers...
SH.
Unsinkable Yacht Project Herry Boat Design 35 02-09-2007 02:54 AM
1956 ChrisCraft Project, your opinion please... PeterH Wooden Boat Building and Restoration 13 03-20-2005 05:53 AM
Project managment/Design job available? Turkey and/or multihulls preferred. catweaselcat Services & Employment 0 11-20-2004 03:06 PM
Yacht Interior Project Managers (X2) Daniel Fenton Services & Employment 0 10-31-2004 06:50 PM
new free design & building project: YAGO 31' steel origami yawl yago Boat Design 1 08-21-2004 12:42 AM
