Old 03-27-2006, 08:44 AM
AnJo888 AnJo888 is offline
Rep: 10 Posts: 2
Scaling up a design
Hello fellows.
I've just got a dinghy project I intend to build as my first one.
The boat is about 1.7 m (5.5') long and I want to "stretch" it a little.
I intend to use an 1.25 scaling factor.
My question is:
Is it ok to apply a constant multiplier to all length mesures, or do I have to consider any other values, due to curved surface? Furthermore, should I use a ticker plywood (letīs say 6mm instead of 4mm) to ensure more resistant longer surfaces?
Thank you for your attention and support.
Old 03-27-2006, 09:39 AM
mmd's Avatar
mmd mmd is offline
Rep: 290 Posts: 378
There are things to consider beyond merely length factors when considering "stretching" a design. In most cases, it is not reccommended to lengthen a design by more than 10%. In the case of a simple ply dinghy, and especially with your first boatbuilding project, why not just get a set of plans for a 2.15m dink? There are plenty of them available, and you won't run into any surprises during construction.
Old 03-27-2006, 09:51 AM
Rep: 10 Posts: 2
Yeah!
I think you're right.
I've got that feeling, in the back of my head, that it was not as simples as multipling the lengths.
Anyway, it is great to be a new member of this forum.
Thank you for attention and prompt response.
scaling models EDM Boat Design 7 03-07-2006 03:57 PM
Scaling up a structure or everthing I know is wrong quilbilly Boat Design 1 10-24-2004 02:12 PM
