Old 03-04-2006, 10:33 PM
EDM EDM is offline
Rep: 10 Posts: 7
scaling models
I have built a half scale (12')version of a power boat I would like to build
(24'). It handles nice but I have some concerns about how things will scale up. Are there any "rules of thumb"?
1) If the half size version is traveling at 25mph is that the same as 50mph
on the full size? Will planing speeds be the same?
2) If 2" by 2" strakes are put on the smaller should they be 4" x4" to have
the same effect on the larger version?
3) Have I learned anything by building this smaller version?
4) Is there any good reference material on this subject?
I do know that when I double all dimensions that the boat will actually be four times larger and that the weight is not to scale. This boat was designed as a 24'.
I would appreciate any help anyone can offer. Thanks in advance!
Old 03-05-2006, 01:31 AM
Raggi_Thor's Avatar
Nav.arch/Designer/Builder
Rep: 696 Posts: 2,457
"Hull speed" increases with the square root of length, so if it's 5 knots now it will be 8. Planing speed is different. You will need the same power per weight, basicly.
Stiffnes increases with the square of the skin thickness.
Yes you hva learned how it handles in a sea, does it plane easily, and so on.
Many books on boat design will cover this.
If you double all dimensions the boat will be eight times as heavy, and the displacement also. Then you need eight times the power...
I think you can nicrease scantlings with a smaller factor than 2, but the the boat will floathigher.
Regards, Kvedja, mvh,
Ragnar Thor Mikkelsen
www.MBOATS.no
Old 03-05-2006, 09:15 AM
RANCHI OTTO's Avatar
RANCHI OTTO RANCHI OTTO is offline
Naval Architect
Rep: 503 Posts: 1,032
Scaling metric units where
Lamda = scale
1) Volume = VolumeModel x lamda ^3 Displ. = Volume x Gamma
2) Speed = SpeedModel x lamda^0.5
3) Power = PowerModel x lamda^3.5
Old 03-05-2006, 08:27 PM
EDM EDM is offline
Rep: 10 Posts: 7
Thanks Raggi Thor and RANCHI OTTO for your replys.
What I am most concerned with is, as I see it, there are two problems with my model. First, even though I sized the scantlings at half scale, I could not do the same with the thickness of all material. ie: hull thickness and bulkheads. So I am too heavy to begin with. Also, since my body weight is a larger percentage of the overall weight and I sit twice as tall in the halfscale version, the center of gravity is way off. However, that works in my favor when I scale up.
The strakes I referred to are lifting strakes, should they double as well? I have been playing around with the bottom shape. Should the larger version plane at roughly the same speed as the model?
RANCHI OTTO, in your equations what is ^.....(pardon my ignorance)
Old 03-06-2006, 03:09 AM
Raggi_Thor's Avatar
"^" means "the power of" if thats correct English.
x^2 = x*x
x^3 = x*x*x
x^0.5 = x to the power of 0.5 or the square root of x.
If your half scale model is stable enough for you, then the full scale boat will be much more stable.
www.MBOATS.no
Old 03-06-2006, 04:52 AM
Naval Architect
thank you Raggi Thor for the "^" explanation.
Old 03-07-2006, 12:33 PM
FranklinRatliff FranklinRatliff is offline
Rep: 84 Posts: 294
Scaling
I'll use 1/10th to keep the math simple.
A 1/10th scale model has 1/1000th the volume (1/10th width x 1/10th length x 1/10th height) of the full scale boat and so to be dynamically similar must have 1/1000 the weight.
Old 03-07-2006, 03:57 PM
Naval Architect
Not exactly if the weight is referred to displacement in salt water.
The model volume*scale^3 and the displacement in salt water = volume*1.026 (metric units)
person models Baldur Boat Design 19 10-31-2005 09:49 AM
Scaling up a structure or everthing I know is wrong quilbilly Boat Design 1 10-24-2004 02:12 PM
3D models for download? Guest Software 3 07-24-2004 02:21 PM
Build Models rjmac Services & Employment 2 02-25-2004 05:13 AM
3d boat models Software 5 12-02-2002 01:45 AM
