| Scale I have a question for the pencil and paper designers. When creating offsets how do you come up with fractions of an inch when using say 1/2 inch scale? |
| why do you think so many countries uses the metric system Simplicity at it's best and no fractions, only decimals![]()
| Ok Wynand so how do read millimeters from a 1/2 centimeter scale?? |
| Chandler, You have to buy an architect's scale (a triangular section one is best) which usually has divisions from 3" = 1' down to 3/32" = 1'. An engineer's scale divides feet into 1/10th divisions, or multiples/fractions thereof, and generally goes 1/10 to 1/60 or 1/80. A metric scale also divides meters in similar divisions to an engineer's scale from 1/10 down to 1/100. Look in any artist/architect supply store, or you can look in the Charette catalog (online???) to see what would suit you. Eric
| G'day Wynand, it beats me why anybody would want to use inches, we had them at school bloody headache. Anyway I reckon metric boats float better than the imperial ones. ![]() |
| By just a fraction....................
__________________ --- Paul --- Northwest Metal Profiling Limited Web site - http://www.nwmpltd.com ""When quality matters"" |
| I see I'm not the only one with an SI preference.... now and then you come across an old (or in the case of Americans, sometimes new) steam plant or something, and it's all in imperial units... so many correction factors everywhere to fix the unit inconsistencies, etc... the same thing in metric often takes less than half the time to solve.... Chandler, it's well worth it to invest in the right type of scale rule for the plans you're working from..... the scale is about $9, and you'll likely make at least $500 of errors if you use the wrong one ![]()
| Thanks guys You're missing the point. I have scales up the yin yang. Someone please tell me how with a 1/2" scale you can determine 1/8ths of an inch in a table of offsets? A 1/2' scale is divided into 24 parts in it's smallest portion. That gives at best a mark for each 1/2", I can see half way between 2 marks, that gives accuracy to 1/4", where do you come up with 1/8ths? From the lofting? Sure, but how many boats are designed and never built, therefore never lofted? Most of them I'd bet. Eric, is there a trick I'm missing? Also Eric what scale would you draw a 34' sailboat on 24x36 paper? |
| My 1/2" to 1' scale has markings for 1/2", but not 1/4" or 1/8". You can interpolate to the 1/4", but it doesn't seem feasible to go to 1/8" precision on a drawing done at 1/2" to 1' scale, that would be thinner than the thinnest lines on the drawing. If offsets are done to eighths, they might have been done from a bigger drawing or with mathematical interpolation methods. Not until I go to 1":1' do I see markings on the scale rule for 1/4", which would make interpolating to 1/8" reliable.
| ok im out of my comfort zone on this one but I think this might help,,,1 inch contains 1000,,,,,,,, 1/2 inch = .500,,,,,thousands,,,,,,1/4 inch = .250,,,thousands1/8 inch = .125 thousands this is machine shop lingo ,,,hope it does some good,,,,longliner |
You don't have to draw the whole boat, only the line or lines you are interested in.
| you need to contact a real mathamatition ,,,,may I suggest dr holyoak of yellow springs ohio.I will see if it is possible |
| jehardiman and Tom Lathrop answered your questions about reading a scale. The fore-shortening method by Tom is used frequently and produces fair lines. As to scale, I like working at D-size, either by hand or by computer, and for a 34' boat, I would likely draw it at 3/4" to the foot. That makes 34' = 25.5" long on the paper. This gives you room for a body plan at one end of the paper. On my Moloka'i motoryachts, I have to draw them at 1/2" or 3/8" to the foot to get them on D-size paper. Eric
| sorry gentlmen ,,I re read my last post and it looks a little wrong ,,I did not mean to take anything from anyone buy using the word (real mathamatition) please dont conscrew this into anything ,,just trying to be helpfull ,,thankyou ,,longliner |
| 1/16 scale J boat | Mitch M | Boat Design | 11 | 05-26-2006 02:42 PM |
| Scale From 1:5 To 1:20 | S Hondros | Boat Design | 3 | 01-29-2006 01:57 PM |
| Small-scale PTO | JPC | Propulsion | 2 | 12-22-2005 10:46 PM |
| scale effects | samh | Boat Design | 2 | 01-06-2005 08:09 AM |
| Scale down? | Zultar | Sailboats | 10 | 02-07-2004 04:46 PM |
