Old 10-11-2008, 11:06 AM
gabdab gabdab is offline
Rep: 10 Posts: 27
sandwich method for subsequent foam replacement ?
Hello,
I am looking for a construction method that allows one to replace ,in case of need, foam in a fiberglass sandwich hull .
This would be usefull for testing different foams for example .
I thought one could just lay fiberglass on a thin sheet of wood forming the hull , then hoocking the foam to the wood sheet by nails or else one could achieve structural resistance and foam isolation from fiberglass ..
Hints ?
Old 10-13-2008, 05:42 AM
Rep: 700 Posts: 3,208
The foam in sandwich construction is STRUCTURAL.
It MUST be bonded to the two skins.
Think how hard it would be to replace the center I in an I beam.
Damaged areas can be cut out and replaced , should you destroy an area .
FF
FF
Old 10-13-2008, 07:18 AM
Rep: 10 Posts: 27
ok , I got to the same conclusion thanks.
Old 10-14-2008, 08:20 AM
Rep: 10 Posts: 27
Would that be the same for polyethylene hulls ?
Foam replacement flyingd Boatbuilding 0 07-23-2008 01:34 PM
flat panel foam sandwich stregenth pescaloco Fiberglass and Composite Boat Building 5 08-18-2007 12:40 PM
25 yr old foam sandwich constructed sailboat jksoft Fiberglass and Composite Boat Building 3 07-27-2007 09:30 PM
PVC Foam or Polypropelene Honeycomb sandwich core plimsoll_line Materials 7 03-20-2005 07:00 PM
Composite foam board sandwich technique scottperkinsusa Boat Design 11 09-18-2004 09:30 PM
