Old 04-29-2009, 07:35 PM
blackdaisies blackdaisies is offline
Rep: 10 Posts: 142
salt water vs fresh water bouyancy in boat plans
I was just peeking in to ask about the water line and balance change from fresh water to salt. Will it have a major effect on a boat usually sailed in fresh water?
Salt water is denser, weighs more, and displaces less, so a boat built for fresh water sailing will act differently on salt water?
Thank you for your time.
Old 04-29-2009, 07:45 PM
Ad Hoc Ad Hoc is offline
Naval Architect
Rep: 1776 Posts: 2,691
If you're talking about a 300m supertanker...yes
If you're talking about a small dinghy...no.
Old 04-29-2009, 11:30 PM
Rep: 10 Posts: 142
It's a small boat, but I was wondering what a difference it would make. Even small ones with ballast or keels would be effected by a relevant change. I was wondering if that would be needed in choosing a design.
Old 04-29-2009, 11:39 PM
Naval Architect
The difference, if a small boat, is so minor it is not worth even worrying about. In reality you wont notice any difference at all, even though there is technically a "difference".
Old 04-30-2009, 09:08 AM
lewisboats's Avatar
lewisboats lewisboats is online now
Obsessed Member
Rep: 1098 Posts: 1,730
The difference is 1.6 lbs/cu ft of displacement. say 16-32 lbs in a smallish boat. total difference in draft is in the order of an inch or less. You'll float a bit higher in salt than in fresh...so bring another case of soda or whatever.
Steve
Old 04-30-2009, 12:19 PM
ned L ned L is offline
Rep: 105 Posts: 44
I can tell you that I remember a 'well previsioned' 46' 1950 Chris Craft floating maybe an inch lower on her lines in fresh water than in salt water, so as said, not a big differance.
Old 04-30-2009, 03:03 PM
Rep: 10 Posts: 142
Is it better to be higher than lower in a design? I would think I would want to build for fresh water and be higher in the water than for it to be lower.
Old 04-30-2009, 03:12 PM
Member
Rep: -33 Posts: 951
Many BC fishboats with greedy skippers have been loaded to deck level in salt water. They do OK until they hit the freshwater of the Frazer River , then they sink like a stone. Not a problem ,unless your decks are awash in salt water.
Brent
Old 04-30-2009, 09:00 PM
Rep: 10 Posts: 142
I'll remember that. You never know when that may come in handy. Don't be a greedy sailor in fresh water.
Battery acid and salt water chabrenas OnBoard Electronics & Controls 37 09-13-2009 01:15 PM
Osmosis - Fresh Water vs Salt Water andy_uk Fiberglass and Composite Boat Building 0 05-21-2008 03:40 AM
Burning salt water Bullseye Hybrid 25 11-01-2007 08:43 PM
Mahogany boat in fresh water smokeonthewater Wooden Boat Building and Restoration 9 09-20-2006 12:07 AM
Density of Salt water Willallison Boat Design 18 02-20-2004 12:12 PM
