Old 01-20-2010, 12:37 PM
Dr Kung Pao Dr Kung Pao is offline
Rep: 32 Posts: 14
Sailboat Design project - lake use
Just thought I would say Hello to everyone and show my design so far. I am just in the beginning phases of putting together a 2 person cruiser for use on protected waters.
The main goals are to make a mellow cruiser for summer picnics and potential sleepovers on the lake.
Feel free to lampoon me, I'm a pretty large target and was born and raised in the desert
any reflections good or bad will be appreciated !
-Jacob
Old 01-20-2010, 01:12 PM
haru haru is offline
Rep: 21 Posts: 50
Nice and exotic.
The keel seems to be good for balance, but the bow may be a problem in bad weather. I feel the stern is too open and stronger wind might cause control problem.
Old 01-20-2010, 01:45 PM
Rep: 32 Posts: 14
Thanks Haru! Do you think it comes down to too fine of a point? The intent isn't to have it about in rough weather, however its alot of work to make a boat for sailing just a few times a year. I would rather have the versatility of a better rounded design, even if she wont be put into rough weather very often.
Regarding the stern, would you suggest tapering it more and trying to inclose it? There is a removable cover I designed to go over it however I could almost see that making the wind situation worse.
Old 01-20-2010, 02:12 PM
Kaluvic's Avatar
Kaluvic Kaluvic is offline
New guy
Rep: 32 Posts: 123
Not sure I'd describe it as a "Mellow" cruiser....kinda cool...but not sure I get it.
The stern bears some resemblance to my Dhows
Sailboat Design project - lake use-dsc08278.jpg  Sailboat Design project - lake use-dsc08277.jpg
Few things should be taken as seriously as the pursuit of pleasure.
Old 01-20-2010, 02:33 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
The hull is certainly unusual, highly experimental at first glance. I tried to figure out your intent or message but I have to admit I don't get the joke.
Dances with Turkeys
Rep: 32 Posts: 14
that it does Kaluvic. Thats a sweet looking Dohw! I love the design of these. Which part is confusing you? Maybe my definition of mellow is a little different then most LOL.
Please say Hi to Lebanon for me. I <3 Beirut!
Old 01-20-2010, 02:39 PM
Rep: 32 Posts: 14
Back view with too large of an area for the rudder.
I guess I wasn't really trying to make a joke, however bringing a smile to someones face can't be all that bad. Maybe more time around sailboats could be the prescription.
Old 01-21-2010, 03:18 PM
mcollins07 mcollins07 is offline
Rep: 156 Posts: 206
Wedge hull
I played with some wedge shaped hulls just as an exercise. See pic below. 12 degrees transverse is supposed to be minimum resistance according to a study on the Internet. sorry I don't have the reference. I seem to remember letting the stern turn up at about 60-62% of Lwl gave good hydrostatic parameters.
Old 01-21-2010, 07:39 PM
Rep: 749 Posts: 1,314
If you do wish to have a boat for the purposes that you describe, then use a conventional design that has a history of satisfactory behavior and performance. If you go way out into left field, as it appears that you have, the odds of being pleased with the result are stacked far too heavily against you. If Bizarre design is your cup of tea then do what you are doing but do not expect great results.
One more thing! Plan for the worst weather and water conditions. Expectations of good weather and the option and time to run for cover is not the way the real world works. Naivete' about such things has led to the demise of many nice people.
Old 01-21-2010, 09:43 PM
Rep: 32 Posts: 14
Thanks mcollins07. Thats some good stuff. That shape looks very familiar.
Messabout you make some very valid points for sure. Maybe I should buy or build a boat as you say of more proven performance for the purpose of family time and then design this as a one person trial or "experimental" craft. I like the way that sounds.
I think I'm going to go ahead and design a small cabin for it and set about making a plan of attack for building. Bizarre design does happen to be on my menu of delights.
Old 01-21-2010, 09:50 PM
Rep: 156 Posts: 206
What about adapting to a trimaran?
Old 01-22-2010, 07:30 AM
Rep: 32 Posts: 14
thats defnately an interesting idea. that seems to make some real good sense to me ! hmmmm
Old 01-22-2010, 10:25 AM
Rep: 32 Posts: 14
hey mcollins07, ady gil was a wedge shaped hull if I am remembering correctly. She sliced throught the waves good enough. Obviously I am not comparing my juvenile design skills with the designers of her however the concept has to be worth something!
Not only that but it has some trimaran charachteristics as well.
cheers!
Old 01-22-2010, 01:00 PM
matt H. matt H. is offline
Rep: 10 Posts: 29
your design seems to push a lot of non buoyancy area forward in hopes
of cutting before floating
its kinda cool
its also has kind of a cultural architectural attribute thing that might work
if its perfect its sound , if its sound its perfect
Old 01-22-2010, 01:15 PM
Rep: 156 Posts: 206
Originally Posted by Dr Kung Pao View Post
... however the concept has to be worth something!
cheers!
Yes, I think the concept could be migrated into a reasonable trimaran design. The trimaran audience is fairly open to experimental deisgns. There is a good bit of technical data on the internet for trimarans.
I would consider Building a boat to use, and Learning Boat Design, two different paths. Either one can take a number of years. However, either one can be very enjoyable, in my opinion.
How did you go about building your paper model? Have you put your design into FreeShip to look at hydrostatics and hydrodynamics?
Lake and River Design for 48' liveaboard paul_tenn Boat Design 10 07-23-2008 06:35 PM
Sailboat Design Project Thorpydo Sailboats 6 09-16-2007 01:47 PM
Hydrofoil sailboat project Panos_na Boat Design 11 11-13-2005 07:00 PM
sailboat project nando10 Sailboats 6 01-29-2005 09:09 AM
Sailboat Project Guest Sailboats 4 01-03-2004 09:06 AM
