Old 11-12-2008, 08:09 AM
gow153 gow153 is offline
Rep: 10 Posts: 7
sail drive vs in-line diesel, opinions please.
Hello all, this is my first post here, but I have been lurking for a while. I will be building a small displacement hull cruiser to do the Great Loop on. The design will be a 27' St. Pierre Dory, something like this. http://www.spirainternational.com/hp_newf.html
My top 3 priorities are seaworthiness, ease of construction and fuel efficiency.
This design is centered around a typical in-board engine design. I know that this is the simplest most efficient design but it also comes along with some down sides;
- Engine compartment takes up valuable floor space in a small boat.
- Puts engine noise and heat right in the cabin.
- Access to engine is limited.
So I would like to get your opinion on using a sail drive, which eliminates some of these problems. Of course it creates it's own set of problems:
- Puts engine weigh far back.
- Drive-train is more complex / less efficient.
http://www.yanmarmarine.com/uploads/...0_TechData.pdf
Here are the engine choices, what's your opinion?
Thanks, Greg
Old 11-12-2008, 08:44 AM
Eric Sponberg's Avatar
Rep: 2547 Posts: 1,426
Actually, the Yanmar installation is very simple, goes into the boat with ease. I have specified it a number of times for sailboats--comes in at least three different sizes for larger engines than the one you show. You'd be happy with it.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Old 11-12-2008, 08:54 AM
Rep: 10 Posts: 7
Eric, I'm assuming your talking about the sail drive. I was not referring to the installation as complex, that part seems simpler that the in-line version. I'm referring to the out-drive, it has to change direction twice. I'm not sure of it's reliability for continuous use. In sailboats it's used on occasion, but in this boat it would be about 1100 hours / year.
Old 11-12-2008, 09:41 AM
Gow153, In my experience Yanmar has been very reliable, although I do have to admit it is primarily with sailboats. If you would like to discuss this further with someone in the know, the people who manage my mooring in Newport, RI, Oldport marine, are agents for Yanmar, and they have installed a lot of these units. You can give them a call at 401-847-9109, talk with Mike Muessel. They can give you advice and point you in the right direction.
Eric
Eric W. Sponberg
Naval Architect
Old 11-12-2008, 10:56 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
gow,
A lightly loaded Dory will not be the most comfortable sea boat, but it probably won't kill you. You need to pay attention to centering weights in such a small waterplane.
The 1GM is not a great engine, a 2 cyl Kubota block marineized by Beta is a far nicer engine to live with for less money including parts at farm price.
The saildrive is an expensive collection of Yanmar parts not intended for continuous duty. Boatbuilders love them because they can be installed by a guy with a saber saw and some glass tape. No running around finding parts, no fitting and aligning bearings, engine, & shaft. But prop size is limited, and a properly sized prop (for your speed & load) is the key to fuel efficiency. For a displacement cruising boat you want the biggest reduction ratio available. As you will be traveling at about 5-6 knots, ideal prop speed will be 5-600 RPM.
Depending on your plans, an electric drive system may make some sense.
Old 11-12-2008, 02:24 PM
Rep: 10 Posts: 7
Originally Posted by Tad View Post
gow,
Thanks for responding, it's funny because the other boat design that I have been waiting to get a better look at is one of your designs, timbercoast 22, http://bartenderboats.com/images/Tim...fo%2010-08.pdf I'm assuming you are the designer.
Again, the same things concern me about an inboard taking up valuable floor space right where I need it most. This just may be one of the compromises that must be made. Can you elaborate on the Timbercoast design and also an electric drive. I'm assuming you are talking about a diesel / electric or some kind of hybrid system?
Old 11-12-2008, 02:53 PM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
If placing the engine is the problem maybe a v-drive? http://www.simplicity-marine.com/ZF/...escription.htm
Old 11-12-2008, 04:06 PM
haybayian haybayian is offline
Rep: 10 Posts: 24
[quote=gow153;237480]Hello all, this is my first post here, but I have been lurking for a while. I will be building a small displacement hull cruiser to do the Great Loop on. The design will be a 27' St. Pierre Dory, something like this. http://www.spirainternational.com/hp_newf.html
Greg,
No matter where it is bolted your engine will take space- relatively speaking- on a 27 footer. If it were my boat building project I would keep the engine setting as simple as possible, that is straight conventional tranny stuffing box shaft prop. Build a dining table over it. Insulate it properly and won't know it is there. This arrangement is the most effective ( no 45 degree angled gear) and can be maintained and fixed by yourself easily, which may well be the case if you plan to motor around the globe. One of my friends last year dove under his sailboat and pulled the prop shaft right out for repair. Try to do that with a sail drive.
Haybayian
Old 11-13-2008, 04:22 AM
harlemriverman's Avatar
harlemriverman harlemriverman is offline
Rep: 182 Posts: 148
Originally Posted by gow153 View Post
...what's your opinion?
Thanks, Greg
in-board, in-line with a honda generator that you can refit in most any sea state as a secondary source of power to the drive train, which in terms of comfort puts you closer to 32' in my humble judgement.
for some reason the dory is coffin of choice for adventurous sojourners. if i were so inclined, and safety my first priority, i would be looking at a design more along the lines of http://www.turbosquid.com/FullPrevie....cfm/ID/168497
Old 11-13-2008, 06:51 AM
Rep: 10 Posts: 7
I think a little clarification is needed based on the responses. This is the great loop http://www.starsongcruising.com/id6.html (not a circumnavigation). It has open water areas in the Great Lakes, Gulf of Mexico, a few runs along the east coast and Island hopping to the Bahamas. I will be in no hurry so waiting for the right weather window will be the rule.
Old 11-13-2008, 07:07 AM
Rep: 182 Posts: 148
ah...
dory's fine. reversing myself, go with the sail drive. the complication factor will be more than compensated by your savings in replacement screws. sounds like a fund voyage.
Old 11-13-2008, 12:07 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
This is a coastwise and protected water cruise, no (or very little) open ocean voyaging. Moderate draft and full prop protection will be a huge advantage.
Without a ton of fish aboard the dory sits on top of the water, the flat bottom means CB shifts very quickly as the boat heels, this means quick righting and quick (tiring) motion. In a deeper hull CB shifts more slowly, she will roll farther and slower, with more gradual increase of righting arms. This is the concept behind the Timbercoast Troller. The deep-vee double-ended hull has fine ends which flare above waterline. She is efficient at low speed, 7.5 knots being max. She also does not change shape much with loading. Full propeller protection behind a deep keel means the boat won't blow all over the ocean at low speed.
For your intended cruise electric propulsion would necessarily be a hybrid system with a substantial diesel charger. Whether such a system made any sense will depend on the specifics of the particular system, and on your individual style of use. If you plan on many longer non-stop hops and anchoring out every night it may not work. But if you intend short daily hops with marina (plugged in) stops of several days the electric solution may be an interesting idea. In my experience these systems are expensive, but for some the convenience pays off. Especially when sneaking up on ducks!
Old 11-13-2008, 12:12 PM
Rep: 10 Posts: 7
gow,
I had Beta marine size my system and this is was they say:
"Thanks for contacting us.
I ran a prop calc, and for boat with a displacement hull, and LWL of
20.17', displacement of 4,600, and transmission ratio of 2.6:1, here
is the performance info:
Beta 14, approximate hull speed = 6.5 knots with 15 x 9 RH three
blade prop
The Beta 14 can run at 3600 RPM all day. So 80% will be about 2880
RPM. That is a nice fuel efficient point to operate the boat. You
should consume something between a pint and a quart of fuel per hour.
The largest gear reduction we have for that engine is 2.6:1. With a
15" three blade prop, your have very nice blade loading and efficiency,
with minimal slip."
That would be a 15" prop. at 1100 rpms. To run at 5-600 rpms I would need a 22-24" prop. and run the engine in an inefficient part of it's power curve. Also a prop. that size becomes hard to deal with physically. I'll see what they say about the V-Drive and sail drive.
Old 11-16-2008, 07:49 AM
Rep: 756 Posts: 3,328
For the trip intend , seaworthyness would be at the bottom of the list.
Frankly I would consider an outboard 20hp Honda or similar.
The inital cost will be far lower than any added fuel cost on a 1500 hour trip.
The advantage in running aground (lots of rocks in much of the Canadian portion) or of simple engine replacement ot repair would be al, to the OB , and a handicap with any diesel.
Sometimes the simplest way IS the better way.
FF
Best surface Drive for Marine diesel? wiggler4490 Surface Drives 171 11-23-2009 02:02 AM
3.0 cobra drive to diesel conversion jake-x Sterndrives 8 03-16-2008 07:30 PM
Opinions on Marine Trader line of Trawlers sought timgoz Open Discussion: All Things Boats & Boating 0 12-23-2007 09:48 AM
Diesel fuel return line johnW Diesel Engines 6 03-14-2007 09:17 AM
Diesel jet drive or electric I/O? MedicineMan Powerboats 4 04-22-2004 11:48 PM
