#31
Any suggestions on a "rule of thumb" to use in determining mast scantlings for small boats? (SA/(LWL*BWL)) isn't directly relevant. The righting moment approach could be used with the simple approximations of the center of buoyancy located a half-beam from center, the CG of the boat on center, and without a trapeze or sliding seat the occupant weight a half-beam on the other side of center. Max righting moment = (weight of boat / 2 + weight of occupants) x max beam This would generally be a conservative over-estimate without a trapeze, etc nor a ballasted keel. Then for an unstayed rig the mast can be sized based on that moment applied at the deck/thwart/partners. If the rig is stayed the standard textbook type analysis can be done. In either case the sail area itself isn't needed, though with rigging the height of the "Center of Effort" may be needed to distribute the load.
__________________ David Cockey Last edited by DCockey : 12-20-2011 at 02:28 PM. Reason: added "without a trapeze, etc nor a ballasted keel" |
#32
| TimothyM, Ignore the "experts" and just go build it, what you have in terms of size of sail and mast will work out just fine. Boat building is as much guess work (based on the practical experience of similar designs) as it is an analytica design process. No one can perdict the maxium loads your particular boat will ever see, all we can is is guestimate on any of it. But as one of my engineering professors used to say: "one simple test is worth a 1000 expert opinions". Go build it and have fun with it. IF something breaks, build a stronger one to replace it. |
#33
| Petros Thank you. that's my plan. I'm not reinventing anything here. I've based everything off of other boats. I just wanted to make sure I was in the ball park. I didn't want to be way under canvased. As far as the spars go, I'll build them on the safe side. I'll post pictures of the build later this winter. |
#34
Take for example a simple plywood skiff,..... Yes it perfectly good approach to get good figures for further analysis or to add a healthy safety factor and build for them. Actually, I find mixing the two approaches to generally be very productive...... I should have written "not very accurate". By writhing "not very productive" I had in mind "the result of such mixing is not accurate enough to engineer with stress 95 % of permissible , so further analysis is required"
__________________ All the stresses in my designs are 95% of permissible. |
#35
Many the "experts" started this way, before becoming too lazy -calculations do not ask for so much sweat as actual building .
| Sail design , area ratios of mainsail & jib ? | dale.frahm | Boat Design | 4 | 05-08-2010 05:44 PM |
| Increasing Sail Area | dm567 | Sailboats | 6 | 01-10-2007 07:36 PM |
| Sail area for cutter? | hiracer | Sailboats | 4 | 07-19-2006 12:31 PM |
| sail area to lateral area ratios | Ian | Boat Design | 5 | 04-07-2004 05:39 PM |
| sail area enlargement | stephan shugart | Sailboats | 2 | 11-07-2002 02:59 PM |
