Old 11-02-2003, 02:26 PM
ongolo ongolo is offline
Rep: 15 Posts: 26
rudder size for long keel 50ft WLL
Hi all,
I am trying to find any info related to rudder size in percentage or whatever relationship to the underwater profile/ lateral resistance, is used.
The rudder is transom hung, but not directly onto the keel, there is a large opening for the prop and the rudder sits quite far back for better leverage to turn, the lower bearing being on an extention of the keel about 800mm from the dead wood ( -steel?)
Initially, I had made a plate ruder, it was one of these times :I got to finish this before I go away" , then I decided to give it a Nac0000 profile and overed the plate rudder with Iroko.
Now I have decided to go from a 45mm shaft to a 60mm shaft, larger flanges etc., because I might go down to Antartica.
The rudder is balanced about 20/80 the rigg is a Gaff schooner with only 120sqm (narrow hull).
Any Opinion most welcome. Thank you.
regards ongolo
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Keel : Rudder Length Alixander Beck Sailboats 54 11-30-2005 10:42 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Cheap And Simple Hi-Tech Keel? Wynand N Boat Design 9 05-24-2005 08:55 PM
