| Rudder relocation due to change in proprotation I have changed engine,gearbox and prop in an 80īs SkiNautique, which prior was reverse rotation, the manufacturer will not give me a clue as to new location. Are there any guidelines or specifics as to how much to move and to which side in relation to the prop-shaft, so the boat will not tourque around itīs own axis. I am sure I am not the first to have done the switch,,,any help wil be much appreciated |
| If the existing set up worked ok before the rotation change, why not measure how far off cntre the rudder is and 'simply' move it the same distance to the other side?
| Newport 27 Rudder?? | MrJunk66 | Sailboats | 33 | 08-03-2009 08:09 PM |
| Pros and Cons of Transom Hung Rudders | Gone Ballistic | Sailboats | 19 | 09-19-2005 09:15 PM |
| Rudder Design and Broaching | joebobb | Boat Design | 0 | 02-25-2005 10:43 PM |
| New Rudder verses Old Rudder | Cliff Ruckstuhl | Sailboats | 0 | 03-06-2004 04:36 PM |
| High Speed Turning Dynamics | Evolution Yacht | Boat Design | 8 | 04-15-2002 04:15 PM |
