Old 11-12-2003, 10:06 AM
woodboat woodboat is offline
Rep: 14 Posts: 312
Rudder question
Parameters: light boat, 6000 Lbs, 28 FT in lenght with a single inboard. Current approximate max speed 28 Knts. What speed advantage, if any, could be gained by moving the rudder from behind the prop and using a twin rudder design flanking the prop on either side?
Old 11-12-2003, 01:08 PM
mmd's Avatar
mmd mmd is offline
Rep: 306 Posts: 378
None to negative, IMHO.
Old 11-12-2003, 01:27 PM
Rep: 14 Posts: 312
Thanks. I asked because I saw an early high performance chris, inboard with twin rudders. It was marketed as high performance for the time. Thinking that the rudder is in the "thrust" that the drag would be more there then out of this wash. I am still hoping that someone has tried personnally and has some hard data. Again thanks for the thoughts
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 07:09 PM
Another Rudder Question (NACA) John Stevens Sailboats 23 04-01-2005 09:31 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 03:36 PM
novice rudder question floatsinksunk Boat Design 5 02-05-2004 01:50 PM
Rudder design question SeaBird Boat Design 19 09-25-2003 05:28 PM
