Old 09-21-2007, 10:04 AM
KnottyBuoyz's Avatar
KnottyBuoyz KnottyBuoyz is offline
Provocateur & Raconteur
Rep: 578 Posts: 615
Rudder post
Do these need to be a solid shaft or is pipe ok?
Boat is a single diesel trawler, 40-50HP, 11,000 lbs.
Rudder will be NACA0012 profile, foam core composite. Inner structure will be 19.4oz per sq yd SAERMAX multiaxial carbon fiber and outer 1708 Biaxial F/G.
Heavily leaning towards bootlegging a design for an articulated rudder which might put a little more stress on the rudder post. Would a 1-1/4" 316L Sched 80 pipe work?
Yours Aye! Rick M/V She:Kon Blog
"It's not the boat "you built" until you've sworn at it, bled on it, sweated over it and cried beside it!" - I just made that up!
Old 09-21-2007, 11:13 AM
SamSam SamSam is offline
Rep: 502 Posts: 1,682
The biggest stress point is above the blade where the shaft goes into the hull. You might put a short piece of solid shaft inside the hollow one where the max stress will be if you need/want to use a hollow shaft.
Old 09-21-2007, 11:18 AM
Rep: 578 Posts: 615
Cool. I was leaning towards a solid shaft from the flange on the top of the rudder shaft up into the boat. Makes sense really.
Old 09-24-2007, 07:31 PM
Rep: 578 Posts: 615
What's the most common material for rudder posts? I'm guessing Stainless but as others have said not ideal for underwater. I'm almost contemplating a carbon fiber post within the rudder blade up to the flange which would mate to a SS flange shaft that goes up into the rudder post packing gland/bearing. Comments? Suggestions?
Old 09-25-2007, 01:25 PM
Rep: 578 Posts: 615
Anybody?
Anybody used carbon fiber tubes or rods for rudder posts?
http://www.graphitestore.com/itemDet...d=34&curPage=1
Old 10-01-2007, 01:39 PM
Gilbert Gilbert is offline
Rep: 28 Posts: 512
I would question your choice of a foil shaped rudder for a power boat.
Even with a balanced rudder blade as you show in your sketch a rudder in the wash of a propellor it will have a few degrees of a dead spot both sides of center where the rudder will not supply a turning moment to the hull unless the rudder is wider at the back than the front. If you have an autopilot, the pilot will 'hunt' in this area causing a delay in steering response. Type www.metalmarinepilot.com into your browser and you can read about some research results on this subject. If you send them information about the rudder and prop size and location they will even tell you exactly how they would recommend you make your rudder. For free.
Sorry but another STRINGER post, please help kapaduch Boat Design 4 02-20-2007 09:01 PM
Outboard rudder vs. inboard rudder designdreamin Boat Design 0 06-27-2006 10:05 PM
Rudder Angle And Effective Size Of Rudder... saildog Sailboats 5 03-06-2006 03:34 PM
I do not think that you allow to post what not belong to you! Sean Herron Boat Design 2 03-13-2005 04:31 PM
Last Post? Option One 12 10-10-2002 05:11 PM
