Old 03-06-2003, 04:14 AM
Gary Gary is offline
Rep: 10 Posts: 2
Rudder position with respect to prop
Can anyone provide me with some rules of thumb or reference sites that may help?
Old 03-06-2003, 05:40 AM
BrettM's Avatar
BrettM BrettM is offline
Rep: 16 Posts: 204
Rule 1 -
Make the distance from the aft end of the propeller shaft to the leading edge of the rudder greater than the length of the propeller Boss! It has happened...
Old 03-30-2003, 09:54 PM
victor victor is offline
rudder position
Metal Marine Pilot of Tacoma, Washington will specifiy what your rudder should look like and where it should be positioned if you send them drawings of your vessel and some other general information. I assume they have a web site. They do not charge for this service, or at least they didn't used to.
Old 03-31-2003, 01:51 PM
Polarity Polarity is offline
Rep: 148 Posts: 480
.. and if you offset it slightly you can get the shaft out /in without removing the rudder...
A quick tip: it would probably help people give good answers if you gave a little more info. eg sail ,power, 5 knots or 50, yacht or ship etc
Old 04-01-2003, 03:21 AM
Rep: 10 Posts: 2
Re: Rudder position with respect to prop
The boat is 11m (aluminium) in length with a top speed of 28 knots. Power plant is a 3216B CAT 450hp. The boat currently walk sideways considerabaly to port when reversing. Steerage to Starboard almost non existant.
The rudder currently is very close to the prop.
Old 04-01-2003, 11:52 AM
Stephen Ditmore's Avatar
Rep: 563 Posts: 1,025
I don't have time to go look it up right now, but Donald Blount wrote on powerboat rudders in a recent issue of Professional BoatBuilder Magazine.
www.proboat.com
Blount and many others do not locate the rudders directly in line with the props/shafts.
On twin installations a little toe-in helps (if you don't have the steering geometry that turns the rudder on the inside of the turn more than the rudder on the outside).
Newport 27 Rudder?? MrJunk66 Sailboats 33 08-03-2009 08:09 PM
Pros and Cons of Transom Hung Rudders Gone Ballistic Sailboats 19 09-19-2005 09:15 PM
Rudder Design and Broaching joebobb Boat Design 0 02-25-2005 10:43 PM
Powerboat rudder design brooksie43 Boat Design 17 01-18-2005 09:52 PM
New Rudder verses Old Rudder Cliff Ruckstuhl Sailboats 0 03-06-2004 04:36 PM
