| I thank you -- certainly going to push for the max. --Had a bit of luck last week at the used metal yard-- came across a 1.75in. dia 316 stainless shaft of the exact length I need with a balanced rudder blade welded in a slot cut into the shaft and the emergengy tiller square nut welded to the top all for the price of retail scrap stainless by the pound. Just have to fabricate a glass foil rudder blade over the present stainless blade. Got to love those metal recycling yards-- Thanks again--Geo. |
| What is the source of that formula?
__________________ David Cockey |
| These are wildly used in Japan including major mass production builder. |
| Humm...yes...well. If you look at it wildly enough there is a twisted sort of logic to it. Water is ~ 850 times as dense as air. What the equation does set the rudder area force to the sail area force corrected by the effective lever arms assuming that hull speed^2 was 1/2 wind speed^2. Psudoscience perhaps, but to paraphrase: "all mathematical models are wrong but some of them are useful".
__________________ A vessel is nothing but a bunch of opinions and compromises held together by the faith of the builders and engineers that they did it correctly. Therefor the only thing a Naval Architect has to sell is his opinion. Last edited by jehardiman : 10-10-2011 at 12:08 PM. Reason: noticed a spelling error after seeing it quoted, dsylexia sukcs |
| So are junk rigged sails, in out traditional image of a sailing craft they look ugly and weird, not my cup of tea, but dam it they work and well at that. Different strokes for different folks as they say.--Like sails I'll stick to the simplier rule of thum calculations of rudder area-- not to say XLR8's is less accurate it's just i'm too dam old to be introduced to new tricks-- but thanks again XLR8 -- your post has introduced food for thought amoung others mathamatically more qualified than me -- Geo.A yacht is not defined by the vessel but by the care and love of her owner--- |
| Rudder area for dual rudder | teoman | Boat Design | 11 | 08-20-2010 04:16 PM |
| Rudder and Lateral Plane Area | bushmanpat | Boat Design | 5 | 07-14-2009 11:05 AM |
| Rudder Area and Balance | Gone Ballistic | Boat Design | 5 | 07-20-2005 12:34 PM |
| Area calculations | Guest | Boat Design | 2 | 06-18-2004 09:43 PM |
| sail area to lateral area ratios | Ian | Boat Design | 5 | 04-07-2004 05:39 PM |
