| Rough seas stability: wide or narrow beam? Hello, What effect beam size has on a boat stability in medium waves 2-4 ft? Like for a power runabout (<20') is it better to have wider or narrower beam? Thank you. |
| If you look at several runabout designs, for a 20' one you may go from 5.5 to 8+ feet beam. Generally speaking oldies had less beam and moderns have more. With 2-4' seas from the beam (and having enough freeboard, of course), I think there is a low risk of capsizing with whatever figure between those (Higher with the lower), but the higher the beam the less comfortable the motion. You'll have to choose... Also take into account that behaviour in waves is not only a matter of beam. |
| As the learned gentleman says it just ain't about beam but having said that generally the wider the beam the safer the ride (not necessarily the more comfortable) the narrower the beam the faster and more unstable the boat! This does not mean that you'll be nice and stable in a square 'biscuit tin', you might live throught the storm but your guts will soon wish they'd died (and you'll be wearing your breakfast)! Other things do have a say in the equation, shape of bottom etc, and of course the safest most stable way is to stay ashore (but that too has it's risks)! ![]() |
__________________ Craig Cavanaugh Silver King Custom Marine No shoes, no shirt, no problem! |
| It's not really relevant but I once was in a 50m long submarine with a gale blowing from the side. We wern't allowed to dive. Hull is long and skinny and completely round except for the tower which turns into a nice breakwater. The sub was rolling about 45 degrees to each side with everything that wasn't duct taped to some pipe flying around inside. With the hatches closed and navigation through the periscope there wasn't any real danger. You just found out very quickly if you had problems with seasickness or not. A further point is the centre of gravity. If it's far above the water line the boat becomes more unstable. |
| Just look at a hunk of board and a broom handle in a bay. The broom handle simply goes up and down , a nice EZ ride. The wide board will follow the surface undulations , heaving pitching & rolling to keep up with the waves. Beam sucks when the waves get BIG. On multihulls the ride can get severe as the boat is on top of an unstable wave system , and the boat follows the wave surface. The long skinney boat (a log ) just rides with a bit of roll. How much roll is determined from how far from a log the boat is. The current crop of 3 story plastic motorboats with an oxygen tent on top would be a sad companion in any sea state on either hullform. FAST FRED |
| Can see which way your going on vessel shape Fred, nice Victorian style easily driven steamboat! Tis OK till you gets a beam sea then the log tends to roll over, as our submariner friend sez (never could get the hang of this submarine stuff, it's the inabillity to wash thing I think, the smell of the deisel don't help either - thought provoking stuff is diesel in a storm)!!![]() |
| For your wee power runabout (<20') it's mostly a matter of wave height. True 4 footers will overwhelm a boat this size. Thus you will be going very slow, and the more beam the better. But in the 2 footers you can scoot along, then less beam will be more comfortable. As Craig noted, lots of these runabouts have 8' or more beam. But that's mostly to accommodate a load of skiers and their beer. Really has nothing to do with seakeeping. Kelly Cook |
| You hit the nail on the head there Corpus "As long as the boat is of an offshore design such as......" As another famous American said 'a lightweight steam roller don't do the job!' |
You'd be surprised how many knuckleheads around here head offshore in "bay" boats, even jon boats Keeps the Coasties in business I guess.
| And the original inquiry by glastron156 was concerning runabouts, not saltwater fishing boats. Kelly |
I just wanted to point out that 18-20' boats could handle rough water.![]()
| Wide jon boat plans? | txslowpoke | Boat Design | 4 | 10-18-2005 09:42 PM |
| New (possibly) idea for monohull stability in rough seas | sryth | Sailboats | 45 | 08-24-2005 06:41 PM |
| Overturn in Rough Seas | Haji K | Boat Design | 7 | 02-19-2005 05:20 AM |
| Narrow Hull Sailing Yachts | Karsten | Open Discussion: All Things Boats & Boating | 6 | 09-08-2004 08:09 AM |
| how long to build a narrow boat | winf | Metal Boat Building | 1 | 08-09-2004 11:18 PM |
