Old 03-18-2010, 10:41 PM
ENG Student ENG Student is offline
Rep: 10 Posts: 12
rough DC motor sizing
Hi guys
im no expert but this just doesnt seem right to me,
Using CAD ive designed a basic hull outline which ive then imported into a CFD package to optimise the drag values.
The Boat is a catamaran design the hull is roughly 9m LOA 1m Beam 1.5m depth and weighs approx 1800kg, without batteries or motors.
From CFD i found the drag to be approx 300N using single phase flow (just the submerged part of the hull)
Now using the instructions on this website
http://www.solarnavigator.net/hull_drag.htm
calculated the required HP required to 2.75HP @ 7knots which relates to just over 2kW power.
Now ive always liked the lynch electric motors so i chose a 3kW motor...which is startlingly small for the size of the boat
Am i just being paranoid or are my calculations completely wrong
PS this is a university assignment im not actually making a boat..just create and analyse the system
Old 03-19-2010, 12:45 AM
Previous Member
Rep: 0 Posts: 0
I have not checked your drag calculation but, if correct, the 2kW will be close. You may do better with a purpose made propeller.
Rick W
Old 03-19-2010, 05:18 AM
Rep: 1493 Posts: 7,447
My 25' Coronado would get to about 5.5kt with a 3.5 outboard. I never optimized the prop which had a bit too much pitch. The displacment was about 4500lbs (2100 kg). With a strong head wind it dropped to about 1kt. I think that 3kw will give the adequate reserve power.
Old 03-19-2010, 08:44 AM
jonr jonr is offline
Rep: 34 Posts: 246
High winds can easily require several times more thrust just to stand still than moving in normal conditions. I'd either overbuild or make sure you are ok with leeway or anchoring and waiting it out.
Best rough water hull you know. xarax Powerboats 85 05-17-2012 05:52 AM
Pod Performance in Rough Water Bowzo8 Powerboats 16 11-21-2010 02:46 PM
Rough water runabouts Jackie3 Powerboats 17 06-27-2010 10:11 PM
Looking at a boat in rough shape durwoodghib Sailboats 36 07-14-2007 08:30 PM
Overturn in Rough Seas Haji K Boat Design 7 02-19-2005 04:20 AM
