Old 05-15-2009, 04:05 PM
simonfraser.97 simonfraser.97 is offline
Rep: 10 Posts: 4
rotating mast, spanner length
10 mast, 35m big roach main.
going to control the rotation with spanner, rope led to 10:1 winch.
spanner 3x depth of the mast ??
tnx for your input
Old 05-17-2009, 04:10 AM
Munter Munter is offline
Amateur
Rep: 100 Posts: 223
The length of spanner required also depends on the rotation point of the mast and whether a vang or a traveller is being used to control the main.
I found that moving the rotation point of the mast to the rear of the mast made rotation significantly easier as the boom wasn't being forced rearward each time the mast rotated.
If you are using a vang (cats or wide monos may not) then this calls for a longer lever than without as the vang pushes the mast out to full rotation.
Although at a completely different scale to yours I used a lever that was 35-40cm long on a mast with 10cm chord length on a rig that used lots of vang for roach control. I hope this helps some.
Cole 43 Rumrunner II - An Australian classic
My home efficiency/renovation blog
Old 05-17-2009, 03:40 PM
Rep: 10 Posts: 4
tnx munter, nice boat too !
Rotating Wing Mast – theoretical discussion Man Overboard Sailboats 111 02-22-2012 05:40 AM
Carbon Rotating Wing Mast SouthernWing Fiberglass and Composite Boat Building 4 12-19-2010 08:40 PM
Rotating wing mast john olsson Multihulls 4 06-11-2007 07:06 AM
Headstay attachment on rotating mast? henrikb Multihulls 3 03-11-2007 05:04 AM
Mast Length on Car Roof??? PI Design Open Discussion: All Things Boats & Boating 16 03-05-2007 07:29 AM
