| rotate a round section or a wing section ? for an 8m tri. a roundish section is going to be much easier to rotate without major shroud adjustment than a wing mast with a short chord. so, in the real world is it better to have a 'normal' rotating mast with a good range, or go for a wing mast that does not rotate fully due to the shrouds ? |
| They can both rotate 180 degrees. The wing mast has the attachments on the forward part or a rotating attachment on top.
__________________ Gonzo |
| It's only the part in the hull that needs to be round and rotating. If you make the stay's and jib to rotate on a ring you can rotate 360 + degrees.
| tnx guys :-) |
| rotated round vs rotated eliptical mast section | Timothy | Sailboats | 9 | 08-25-2009 12:19 AM |
| GL: The section modulus | VVC3k | Class Societies | 0 | 01-22-2008 04:11 AM |
| naca section | jejojoy | Propulsion | 3 | 10-09-2006 08:53 PM |
| naca section | jejojoy | Propulsion | 11 | 08-23-2006 06:05 PM |
| Section locations | Willallison | Software | 1 | 07-21-2003 01:07 AM |
