Old 01-10-2009, 04:44 PM
JonathanCole's Avatar
JonathanCole JonathanCole is offline
imagineer
Rep: 58 Posts: 436
Rolling hulls
This is probably a really dumb question because I searched BD.net on this topic and came up with nothing. But since I have actually seen rolling hulls employed on simple pedal boats, there must be some information out there about how to calculate their performance, efficiency, etc.
On the plus side having a very large surface area to couple with the water may have the benefits of low rotational speeds as in a paddle wheel drive. If the hulls are also the drives, then the issue of wetted area may have to be thought of differently as such hulls roll instead of simply splitting and pushing the water aside. On the other hand, the lifting of water by such hulls is exactly the opposite of the desirability of minimizing wavemaking. Every ouce of water lifted above the waterline is work that does not in and of itself move the hull forward.
Rolling hulls can include blades, either articulated or not. They can roll on axes perpendicular to the direction of the boat (as in most pedal boats) or parallel to the direction of the boat which would require some sort of helical texture or blades on the rotating hull.
Anyone have any ideas on this.
Damping Coefficient on a rolling boat alock Education 1 09-26-2008 05:20 AM
Is rolling and tipping this easy mongo75 Fiberglass and Composite Boat Building 45 03-13-2008 09:06 PM
looking for anti rolling gyro SKM Materials 3 05-09-2007 08:56 AM
Ship stabiliser to reduce rolling ritinkarsen Boat Design 6 11-08-2005 06:06 AM
Anti Rolling Gyros ivansalasj Boat Design 0 05-28-2004 05:33 PM
