| Roll Stablilisation - Bilge Keels Does anybody have direct experience with the effects that the addition of bilge keels have in terms of reduction in speed. rather than guess's I'm looking for quantative results based on real experience. The question is asked in relation to possible fitting of bilge keels to reduce the excessive rolling on a semi-displacement round bilge boat which currently operates at about 18knots. Any fitting of bilge keels would be done in the most effective manner with tank testing etc. to establish the flow lines. thanks, Michael |
| We have 8 inch deep about 30 ft long 3/4 thick bilge keels on our Ex Usnavy Utility launch. They seem to work with no loss of speed compared to other launches. But its only a 12K boat that seldome goes that fast. they should be strong enough to take the ground , good way to protect the keel cooling. I would only add the computed surface area (minor) to the hull surface for calculations. They DO work when the vessel is stopped to reduce the roll. For a fast boat the Quantum stuff seems great although big $$$. Works at anchor TOO! Perhaps the cost can be defrayed by the use of the stab fins for hydronamic lift at high speeds. Framm roll tank is still the seamless choice , but lots harder to engineer. FAST FRED |
| Twin keel research | MikeJohns | Boat Design | 125 | 06-16-2009 11:44 PM |
| bilge keels | roxanne parola | Sailboats | 21 | 03-10-2006 11:35 PM |
| Bilge Pump Activity Monitor | odysseyII | Electrical Systems | 4 | 11-11-2005 06:21 AM |
| 12v Bilge pump timer/delayed shut-off...? | paularey | Sailboats | 5 | 11-04-2005 03:39 PM |
| LONG Bilge Keels | FAST FRED | Boat Design | 14 | 10-25-2005 02:36 AM |
