Old 10-23-2006, 04:58 AM
Alik's Avatar
Alik Alik is online now
Rep: 1070 Posts: 2,036
Rig with diamonds - calculation method?
Interested in method to calculate rig with diamonds for sailing cat. Any links/ideas?
Old 10-23-2006, 09:45 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
if thats area you mean Guilermo has a triangle m2 calculator on his site
two triangles is a diamond but maybe you mean something else
Old 10-23-2006, 10:02 AM
Alik's Avatar
I need to calcualte diamond shrouds loads.
Old 10-23-2006, 01:16 PM
yipster's Avatar
allrite, now i see what you mean. guess best try efunda or let this trhead ride
meanwhile found references to
Rigs & Rigging of Yachts D. Phillips-Birt Adlard Coles 1954
Skene’s Elements of Yacht Design F.S.Kinney Dodd, Mead 1981
Principles of Yacht Design Larsson & Eliasson Adlard Coles 1994
Mischief Goes South H.W.Tilman various publishers
at http://www.classicmarine.co.uk/Artic...ging_loads.htm
and more schrouding at http://web.usna.navy.mil/~phmiller/J...lJ24report.pdf
Old 10-23-2006, 06:36 PM
naval ark naval ark is offline
Member
Rep: 19 Posts: 27
You just calculate the load the same way as you would calculate a cap shroud load, for example.
The wire isn't taking any more load, just redirecting it from the deck (or spreader base where it is picked up by another shroud) back to the mast.
Old 10-24-2006, 10:56 AM
yipster's Avatar
interested in the dogstar below waterline hullform reading john shuttleworths site again i also read
"The rig is very tall and a carbon mast will be the lightest option to reduce pitching, and all the rigging apart from the forestay and diamonds will be synthetic fibre instead of stainless steel to reduce weight. Diamonds will be stainless rod for minimum stretch and lowest windage."
thought the stainless rod worth mentoning, carbon and stainless is another study...
Sail Loading on Rig, Rig Loading on Vessel brian eiland Sailboats 93 02-23-2011 07:19 PM
Mast Deflection with diamonds Toby P Sailboats 7 01-17-2006 09:42 AM
The best fairing method? Capt. Chris Fiberglass and Composite Boat Building 6 10-07-2005 05:47 PM
Spreader to diamonds PhilT Sailboats 5 02-17-2005 08:39 PM
Help with One-Off Method LBS Fiberglass and Composite Boat Building 6 02-11-2005 10:12 AM
