| RIB - 6.5 m I am planning to go into 6.5 m RIB Production and need advice ( lots of it , actually) from you all. First - The hull form - I decided on a series 65-b SNAME hull form , which is a deep V with high sheer at for'd and a number of flat chine strips all along. Supposed to be good in wavy seas too. Second - Construction - If the target is to make them in large numbers, is it worthwhile to make it by Vacuum Infusion technique? Where do I find good guidelines on this? I believe the joining of the inflatable with the hull and the lifting points are the most common areas of failure ( feedback from the coast guards). Suggestions? Third : I am planning to make one prototype first and go through the pains before I embark on it. all suggestions/ideas/advice are welcome. Looking forward to hearing from all of you. RGDS Bijit Sarkar |
| Existing threads Did you look into this thread already? http://boatdesign.net/forums/showthr...highlight=tube There are some more threads on RIB's with usefull information also on vacuum Infusion. |
| Thanks That was great . Lots of useful info. Looks like I will make the RIBS after all. ![]() |
| do you have a picture of what you want to build? |
| SOmething like this ---as attached. |
| RIB designers | royalray | Boat Design | 0 | 07-14-2005 05:09 AM |
| RIB Seaworthiness | operator | Boat Design | 8 | 05-20-2005 08:42 AM |
| catamaran vs rib | hilux38 | Boatbuilding | 3 | 12-10-2004 09:11 AM |
| rib help | billboat10 | Powerboats | 1 | 05-16-2004 12:42 AM |
| RIB Design help | bobber | Powerboats | 2 | 05-10-2004 11:43 AM |
