Old 11-30-2007, 12:04 PM
tallen tallen is offline
Rep: 10 Posts: 30
Rhino Marine Stability Curves
Hello, I am working on a model in Rhino Marine and I am trying to figure out how to get the stability curves. You can output to Excel and get some curves however it always places stability at 0. This is because the only way it seems to output over a range of waterlines is to use the waterline height increment which does not allow you to enter in model weight data. Is there anyway I can enter in LCG, TCG, VCG and have it plot it over a range of waterlines?
I really need to figure this out fast so any help would be appreciated. Thank you.
Old 11-30-2007, 04:49 PM
Rep: 1623 Posts: 2,343
If you are using waterlines you are defining vessel displacement by waterline so to enter a displacement would be contradictory.
Run your model upright on your first displacement and final displacement note the waterlines, tick the waterline range and enter your desired range of waterlines from the min to the max noted before.
Enter the COG as normal. The righting moment curves will be correct for your range of waterlines (displacements).
Mike Johns.
Stability calcs from Rhino model tallen Software 11 11-05-2007 12:18 PM
Can rhinomarine cauculate Cross curves of stability? bbsboat Software 7 10-09-2007 03:57 PM
Interpreting Stability Curves JCD Stability 27 10-06-2007 02:52 PM
Rhino Curves jmedick Software 6 06-27-2007 02:34 PM
Wanker 36 stability curves, understanding tranmkp Sailboats 1 07-26-2004 07:15 PM
