Old 07-29-2011, 05:13 AM
Guinther Guinther is offline
Rep: 10 Posts: 6
Rhino help - How to align surface edges to a closed curve?
Hey guys,
I've been trying to model a concave shape with edges in different angles. Although I can make the concave shape, I cannot make its edges on the angles I need. I am sending the file in 3dm in attachment. The surface edges should match with the red line. If you have some time and like to be challenged, please help me to solve this.
Thanks in advance.
Regards,
Guinther
Old 07-29-2011, 05:32 AM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
Some things are geometrically impossible, unless you drop some of the constraints. This one is one of them. It is impossible to create a continuous concave surface from the edges arranged in the way these are arranged. The surface you have created shows it clearly. The planar (X-Y plane) shape of its borders is correct and consistent with the planar shape of the edge polyline, but the elevations are not because they just cannot be met with a simply concave surface.
Cheeers
Old 07-29-2011, 05:45 AM
Rep: 10 Posts: 6
I thought it was impossible... but I needed to check. Now I know it. However, starting the problem from its origin: I received this file (attachment) from a customer and I need to fill in the gap with the same context. I don't know what was the method used to model the other parts, but it seems almost impossible to model that gap with only this information... One of the methods I can imagine is to create a box and several spheres on top of it and then boolean difference. But then I would have to start from beginning...
Any other suggestions?
Thanks.
Cheers!
Old 07-29-2011, 07:25 AM
daiquiri's Avatar
The problem is lacking some essential info. Without knowing what's around that gap and surface continuity constraints, you can do whatever you like to fill it. Even stuff like the one I've attached here.
Cheers
can I bond edges surfaces from rhino in maxsurf easily? a78 Software 4 04-04-2009 04:27 AM
can I bond edges surfaces from rhino in maxsurf? a78 Boat Design 0 03-31-2009 06:51 AM
Lost or curve network in Rhino ivansalasj Software 2 06-04-2007 01:26 AM
Fitting a Curve to Offsets Points in Rhino CET Software 6 01-04-2006 08:31 AM
Surface thickness - in Rhino Willallison Software 6 11-30-2003 04:34 PM
