Old 04-01-2005, 07:16 AM
yipster's Avatar
yipster yipster is offline
Rep: 1083 Posts: 3,337
hooverspeed has something the same since some years.
i can find booking, hotels and car rent but this is the only picture?
thats what boatdesign means to the world i guess
Old 04-03-2005, 06:03 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Yipster,
The Hoverspeed boats are built by Incat here in Tassie. Go to www.incat.com.au for more pics..
Will
Imaginocean Yacht Design
www.imaginocean.net
Old 04-04-2005, 03:10 AM
lucdekeyser lucdekeyser is offline
Rep: 45 Posts: 28
Kvaerner Innovative Designs
Beauty is in the eye of the beholder. To my eye, reverse bowed Kvaener's "Super Liner 300", pictured below on http://foxxaero.homestead.com/indrad_038.html sure's got it.
Luc
Old 04-04-2005, 02:28 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
Not pretty? We disagree.
http://www.sms-navy.com/SMS_Baden-ptbow-top.jpg
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 04-08-2005, 10:44 AM
Oyvind's Avatar
Oyvind Oyvind is offline
oxmarine.com
Rep: 60 Posts: 38
Reversed bows
Dear Sirs!
Glad to see that You all have opinions on reversed bows! The picture on the top, the red boat, is actually called ULSTEIN AX0X and was designed by me back in June 2003 (I work at ULSTEIN DESIGN in Norway, doing hulldesign and overall design). It is an Anchorhandling Tug Supply Vessel using diesel-electric propulsion. It has been an idea of mine since 1997 to use these bows commercially, and this boat represents a vision.
This week we actually launced a building contract for a boat using a reversed bow! It is called ULSTEIN AX104, and is somewhat different from the earlier mentioned boat. Check out http://www.ulsteindesign.com! We've tested it throroughly, and to You sceptics out there; it works like nothing else! It is not a wave piercer, but works more like a dolphin! I'm introducing a new volume distribution, different from what most people think, and we found lower speed loss in waves, lower heave and pitch accelerations, NO slamming, NO green water on bridge deck etc. We call the bow X-bow, patent pending. This boat also have diesel-electric propulsion using azimuthing thrusters, and also have a new safe anchorhandling system - SAHS, patent pending.
It's been a busy couple of years!
Br
Oyvind
Old 04-08-2005, 11:07 AM
quicksail quicksail is offline
Rep: 25 Posts: 58
Thanks for your reply Oyvind. I hope you don't mind me posting your design. I was just very intrigued by your design along with other designs with reverse bows. It is a definite shift in design philosophy and is very striking to say the least. I am interested in the development of these designs and the benefits gained. Thanks for filling me in on some of the possible benefits.
I was wondering though, how you can patent something that aready exists. I find patenting things like CBTF and reverse bows very hard to do as many versions already exist from the past and present. I understand that there is a lot of detail not mentioned. These sorts of patents can't be generalized, they must focus on specific design features. Anyway thanks for your insight and I look forward to seeing your ship launched. It may be the start of a new design trend. Who knows.
Old 04-09-2005, 09:29 AM
cyclops cyclops is offline
Rep: 33 Posts: 1,059
Reverse curve bows are very efficient at reducing the bow wave. Most all new with it ship designs have a subsurface bow bulb to reduce bow drag. High speed, + 40 knot, Catamaran ferries are equipped with them. If the "new" marine designers come up with more new hull improvements, they will have to pay royalites to the dead. Even the "new" Q E 2 has a massive bow bulb and makes almost no wake at any speed. ------------------------------------------------The only real possible negative would be lifting the bow fast enough in a strong storm at sea? I have never seen side by side data of the same ship run with each type of bow in storm conditions. Maybe USN carrier design has a set?
Old 05-11-2005, 08:47 AM
brian eiland's Avatar
Rep: 1577 Posts: 2,737
Reverse Bows
This VSV hull technolgy makes use of reverse bows, http://www.vsvboats.com/
in looking at some of the photos in operation, the bow disturbance wave appears minimal
...and then this catamaran's ugly reverse bows (in my opinion, of course I'm not a big fan of the over-utilized plum bows on cruising designs either)
1) http://www.victorinox.com/newsite/en.../katamaran.htm
2) http://www.kkg.at/de/93/
RunningTideYachts.com
Distinctive Expedition Yachts
Old 05-12-2005, 01:09 AM
Rasman Rasman is offline
Rep: 10 Posts: 14
My observation is based on logic rather than formulas etc, but I can imagine a boat of this design could travel into a large swell and experience very little motion. My reducing the rate of bouyancy gain, you would inevitably reduce the bounce effect. Any other hull would jump off a wave, I beleive a hull like this would dive into a wave and come out the other side with minimal effect on ride comfort. Not sure about efficiency etc... Cant imagine it would be particularly beneficial to efficiency.
  #25
Old 05-12-2005, 08:56 PM
marshmat's Avatar
marshmat marshmat is offline
Rep: 1958 Posts: 4,114
Back in the mid-nineties Kvaerner Masa-Yards was working on a 225-metre Ro-Ro freighter concept that had the most radical reverse bow I've ever seen... http://www.masa-yards.fi/ but I can't seem to find that particular design anywhere.
The wave-piercing designs, which usually incorproate a reverse bow to some degree, run faster with less pounding and heaving than a regular hull. Some claim that a monohull like the red one above, or the RoRo225, with a reverse bow extending all the way to the bridge, is more seaworthy than a conventional bow (if you stuff the bow into a huge wave, the boat cuts through it rather than taking on water). But for most applications the tradeoff in reduced deck space and hull volume isn't worth the higher efficiency and whatever unknown seakeeping abilities it may give.
  #26
Old 05-23-2005, 02:34 PM
SailDesign's Avatar
Old Phart! Stay upwind..
Rep: 645 Posts: 1,723
Oyvind,
Congrats on getting your ugly mug on the front cover of Maritime Reporter! Almost life size, too.
Steve
PS - nice bow....
  #27
Old 05-16-2008, 09:28 PM
oldsailor7 oldsailor7 is online now
Rep: 269 Posts: 1,118
Look at a picture of IDEC or SODEBO.
  #28
Old 05-21-2008, 04:39 PM
charmc charmc is offline
Rep: 840 Posts: 2,391
Powerboat reverse bow can look good
Interesting reverse bow megayacht by Feadship:
During the launch ceremony at the Koninklijke De Vries yard in Aalsmeer (NL) on 5 January 2008, all eyes were on Predator’s sensational reverse bow. This bow forms part of the aggressive new styling brief at the core of the client’s wish-list. “The owner arrived at the yard in late 2004 with a request that we partner on something different than anything else afloat,” comments Henk de Vries. “Together with De Voogt Naval Architects and Bannenberg Designs (interior), we have created a super-sleek and highly sophisticated yacht that is genuinely innovative.”
http://www.yachtforums.com/forums/ya...-predator.html
Best,
Charlie
  #29
Old 05-21-2008, 04:45 PM
Reverse bow benefit
"By sweeping the bow backwards from the waterline, up… an oncoming wave encounters less resistance in contrast to a conventional forward-flaired bow. Essentially, an oncoming wave washes over the top of the deck and dissipates, as opposed to being displaced outward by a conventional bow." from discussion of Blohm & Voss's Sigma, an even more radical design, whose reverse bow's visual impact is matched by a unique superstructure.
http://www.yachtforums.com/forums/ya...ter-sigma.html
Best,
Charlie
  #30
Old 05-21-2008, 05:05 PM
You need more than just a big yacht to impress folks these days ...
Still another reverse bow megayacht, this one from Lurssen, designed by Igor Lobanov:
http://www.superyachttimes.com/edito...rticle/id/1102
Why these radical designs? Well, it seems that boredom is setting in among the super rich. In fact, according to Mr Lobanov, "No longer is a 130m yacht so unusual or so impressive."
Best,
Charlie
Volvo Penta SP drive no reverse Bragg Brothers Sterndrives 5 08-10-2011 10:46 AM
Windshield Reverse Rake robrohdeszudy Powerboats 11 07-18-2005 05:35 AM
Prop Efficiency in Reverse phillip Props 3 05-01-2005 10:36 AM
faster backwards nero Boat Design 23 03-06-2005 11:49 AM
Bulbous bow design tjrrong Boat Design 4 01-05-2005 04:24 AM
