Old 04-19-2006, 04:08 AM
Roly Roly is offline
Rep: 222 Posts: 471
Respacing floors
Shifted to design.....hopin for a response.
If respacing structural floors (with keel bolts) within minimiums and maximums (centers) laid down by the designer, does the minimum center's (max number of floors) dictate the total xsectional area required by the floors? That is if if you increase the centres and decrease the number of floors you must proportionally increase the xsectional dimensions of each member?
Apologies for the 20 questions, but I am trying to get my head around the essentials here.
Is the xsectional area a constant?
Old 04-19-2006, 03:36 PM
Thunderhead19 Thunderhead19 is offline
Rep: 21 Posts: 504
No, it isn't.
JDF
'"Forward, the Light Brigade!"'
-Alfred Lord Tennyson
Old 04-19-2006, 04:33 PM
Rep: 222 Posts: 471
Duh! ....not thinking clearly.
Of course, it would be more dependent on the size of the moulding.
So the greater the moulding dimension of the floor, the larger the centres can be and less floors because of the larger bending moment of each floor?
(For an approriate minimum siding.) Xsection would be for shear only.......am I correct?
Also, is it standard practise to add on to the sided dimension of a floor the diameter of any bolts through it reducing that siding?
Respacing floors..... Roly Sailboats 0 04-18-2006 04:46 PM
Replacing stringers and floors crum731 Fiberglass and Composite Boat Building 4 03-10-2005 06:08 PM
cold galvanized floors Boatbuilding 3 02-16-2003 04:31 PM
