Old 05-04-2010, 06:22 PM
Doug Lord's Avatar
Flight Ready
Rep: 919 Posts: 5,597
Resistance Testing-Planing Hull Sailboat
The hull I want to test is almost 18' long and will be tested at different weights. The boat will use a small hydrofoil on the daggerboard and one on the rudder. The point of the testing is to optimize the size of these foils to assure that they actually benefit the design more than they hurt it. The foils are there to improve speed and handling-not to fully fly the boat.( "foil assist") I'm associated with a marine testing laboratory that will help-they'll set up the data collection so that resistance can be accurately measured and referenced exactly to speed and set up to be easily analyzed.
The lab has not done this kind of tow testing before but they have a wide background in testing to various standards of almost every marine component-mostly powerboat components,tanks, bilge pumps, wheels, hydraulics ect.
My proposal is to attach a tow line to a mast stub with the attachment point at the CE of the rig and test between 0 and 20 knots with the boat level(athwartship).
Foils would be tested at different angles of incidence according to a plan that we will develop. The boat will be tested with a "plain" daggerboard and rudder and then with the foil equipped boards.
Some questions:
1) should the towing be done outside the wake of the towboat-will that turbulence affect the results?
2) seems to me that initial testing should be done in flat calm water-no waves?
3) should the tow line from the boat be kept relatively level instead of going at a down angle to the towboat?
I would appreciate any suggestions or comments particularly if you have testing experience. Thanks!
picture of model of boat to be tested:
Resistance Testing-Planing Hull Sailboat-trapwing-proto-test-1-2-3-002.jpg  Resistance Testing-Planing Hull Sailboat-trapwing-proto-test-1-2-3-003.jpg
yes, it is a revolution
Old 05-05-2010, 03:23 AM
jwboatdesigns jwboatdesigns is offline
John Welsford
Rep: 46 Posts: 33
Ive done some testing on a hull of about this size and proportions, it was a foil stabilised type but my students ( marine design degree, third year) had a ball testing it with all sorts of lift and stabilising foils.
Tow it in undisturbed waters, dead flat water, keep the towline as close to parallel with the waters surface as possible to minimise trim changes, it may help to radio control the rudder so it can be made to track properly.
Hope that helps
John Welsford
Some questions:
Old 05-05-2010, 04:41 AM
daiquiri's Avatar
Engineering and Design
Rep: 2574 Posts: 2,731
Doug, are you testing a full-size boat or a scale model?
Old 05-05-2010, 09:27 AM
Doug Lord's Avatar
Flight Ready
Hope that helps
John Welsford
Thanks, John! I think I'll ride the thing so I can adjust the foils-if I'm not too scared. It needs the weight anyway. I appreciate your comments very much. Crew weight the same-wing ballast changed....
Doug Lord's Avatar
Flight Ready
Slavi, the full size boat.......
Old 05-05-2010, 02:35 PM
Rep: 1758 Posts: 1,561
For something that size there is always NSWCCD.... anyway...
When high speed models are tested, there is usualy a need for a cricket or two point dyno to constrain the model in yaw as there is no active control to prevent kiteing. On an 18' model yaw may be considerable. A two point dyno will also help in determining the directional stability derivatives.
Old 05-05-2010, 03:05 PM
Doug Lord's Avatar
Flight Ready
As it stands now,I'll be in it steering it -just as I would be under sail.....
PS-what is "NSWCCD" ? Naval Surface Warfare Center CD???
Old 05-05-2010, 04:26 PM
As you think: Naval Surface Warfare Center Carderock Division...The David Taylor Model Basin for us old folks. The "slow, deep" tank carriage will do 20 knots, the "high speed" basin will do 50. The models are about the size of your hull.
Two parallel towing tanks are located at the Naval Surface Warfare Center, Carderock Division (NSWCCD), in Carderock, Maryland. One tank is subdivided by a bulkhead to provide two independent basins with separate carriages. The first basin includes a deep section 6.7 m deep, 271 m long, and 15.5 m wide, and a shallow section 3 m deep, 92.4 m long, and 15.5 m wide. The carriage has a maximum speed of 9.3 m/s. The adjoining second basin is 6.7 m deep, 575 m long, and 15.5 m wide, with a pneumatic wave maker at one end and a wave-absorbing beach at the other. The carriage in this basin has a maximum speed of 10.3 m/s. The other towing tank, known as the high-speed basin, is 904 m long with a deep section 4.9 m deep, 514 m long, and 6.4 m wide and a contiguous shallow section 3 m deep, 356 m long, and 6.4 m wide. A pneumatic wave maker is at the deep end and an absorbing beach is at the shallow end. Two carriages are located in the high-speed basin, with maximum speeds of 16.5 m/s and 25.7 m/s.
Old 05-06-2010, 04:41 AM
Alik's Avatar
Alik Alik is online now
Rep: 1070 Posts: 2,036
1. Keep towing line length at least 4 times longer than length of tug boat - this is important to minimize effect of tug's propeller and wake flow.
2. Towing point - it is good to have it at same level as CE of sailing rig;
3. If the model/boat is asymmetrical (if it is stabilized on one side), it will yaw(drift) to one side, so towing rope will not be parralel to tug's CL.
Old 05-06-2010, 08:50 AM
Doug Lord's Avatar
Flight Ready
Thanks, Alik! The boat is symetrical and a full size working prototype.
hull model testing wardd Stability 18 11-25-2009 03:08 AM
planing catamaran hulls/sailboat terabika Boat Design 16 06-02-2009 08:20 PM
Hull testing software innov-8 Software 1 05-06-2009 04:06 AM
Power/Resistance Calculation for Planing V-Hull & Fuel/Engine Required Kapitan_Raider Outboards 24 11-26-2008 04:34 AM
Planing sailboat theory question. ErikG Boat Design 2 07-22-2003 02:13 AM
