Old 05-11-2011, 05:11 AM
Coongle Coongle is offline
Rep: 10 Posts: 4
Rescue Samson Post Location
Hi
We are looking at a tender for a small Tow / Rescue boat 20' / 6 m LOA
Vessel is outboard powered 150 Hp with an OB well so we are mindful that we need to clear the outboard. The tender requires the samson post to be as far forward as practical to enhance maneuvering around the stricken vessel.
Can anyone shed some light on this as far as their experience with similar Vessels in this range and type?
Attached is a photo of a sister vessel we intend to use.
Cheers Coongle
Old 05-11-2011, 05:20 AM
Dean Smith Dean Smith is offline
Previous Member
Rep: 0 Posts: 0
yes well normally your samson post would be well forewards, but you have structural issues and tow cable will sweep cockpit So I would take the tow on a bridle from side decks as far forewards as possible
You can easily bracket (gusset knee) under the side decks and use a bridle say 15 feet long with a quick hitch onto the main cable
Old 05-11-2011, 05:26 AM
Rep: 10 Posts: 4
Thanks Dean,
We will try this out asap and see if the Crew are happy to use a method like this.
Cheers Coongle
Old 05-11-2011, 06:48 AM
TeddyDiver's Avatar
Gollywobbler
Rep: 1348 Posts: 2,052
The best way IMHO is to tow with cable fastening around the engine or with a bridle attached to OB bolts. This way there's no excess stress for the hull stuctures.
Old 05-11-2011, 08:20 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
The only really good way to tow is with a samson post forward of the motor or rudder, if its an inboard. Using a bridle helps a bit but still steers the tow boat which can be very troublesome in close quarters. Firm orders to the person in the towed boat to follow in the track of the tow boat is absolutely necessary if the tow is attached the stern of the tow boat, bridle or not. The bridle on the side decks idea may work but is likely to catch the motor or something else or even somebody. Good in an emergency but no substitute for a well placed samson post.
Tom Lathrop
Old 05-11-2011, 08:32 AM
Rep: 1493 Posts: 7,447
An arch over the motor with a towing cleat may work. That boat has a high freeboard, so it wouldn't need to be too tall.
Old 05-11-2011, 08:45 AM
keysdisease's Avatar
keysdisease keysdisease is offline
Rep: 205 Posts: 442
This is how it's done on O/B powered RIBS. Like Gonzo said, an arch over the motor(s). And like Tom said, if the tow attachment point (samson post) is forward of the motors (rudder) the tow vessel will have a MUCH easier, safer and more maneuverable time.
In the picture note the reel of tow line and the arch.
Steve
Old 05-11-2011, 11:01 AM
TeddyDiver's Avatar
Gollywobbler
Thou you may do your towing anyway you like it might be illuminating to draw the force vectors and figure out how they affect. Having a samson post is the way to go... for a vessel with inboard engine.. towing with OB is different..
Old 05-11-2011, 12:01 PM
Submarine Tom's Avatar
Mariner
Rep: 937 Posts: 1,941
This is all good advice you've received.
I have many hours operating a 500Hp OB rescue tow boat and a 42 foot commercial tug.
One word you should be more than familiar with is "girding".
Good luck.
-Tom
Old 05-11-2011, 04:37 PM
Previous Member
Rep: 0 Posts: 0
Good luck.
-Tom
hiya Tom
when I was at sea on the Chippy T in North Sea, I can see the burn on the galley bench, the coffee pot, all the crew were on deck as the cable swept over the deck and killed a man. I was not aboard at the time
Only thing I would say here is
Make sure there are no iron hooks on the rope end and look after you quality rope
Old 05-11-2011, 07:07 PM
Rep: 10 Posts: 4
Samson Post Drawing
Thanks for the info from all of You
I am very happy to have with the feedback.
The drawing attached is what we are considering now.
The removable arch might be fixed with a hinged section to aid the access to the man overboard ladder.
thanks for all the good advice and photo's
Cheers Coongle
Old 05-11-2011, 07:11 PM
Rep: 10 Posts: 4
Samson Post
Originally Posted by keysdisease View Post
This is how it's done on O/B powered RIBS. Like Gonzo said, an arch over the motor(s). And like Tom said, if the tow attachment point (Samson post) is forward of the motors (rudder) the tow vessel will have a MUCH easier, safer and more maneuverable time.
Steve
Thanks Keysdisease,
After viewing your posted photo I can see we may be better to shift the arch aft justs forward of the transom. I am sure some trail and error is needed before we can safely say this is 100%
Cheers Coongle
Old 05-11-2011, 07:29 PM
Looks very good to me.
Tom Lathrop
Old 05-15-2011, 07:41 PM
Willallison's Avatar
Rep: 2319 Posts: 3,502
Cheers Coongle
I would suggest that you sweep the arch further back over the outboard. The attachment to the deck would remain in the same place, but the arch itself would be better with a continuous and gentle curve. I've had experience with little 'stubby' arches like that and the rope tends snag on the uprights before 'popping' over the bend.
Will
Imaginocean Yacht Design
www.imaginocean.net
5 m Fast Rescue Boat Design - Comments and Suggestions cnzlp Boat Design 10 09-21-2010 06:17 AM
Need plastic/foam advice for rescue boat john zimmerlee Materials 4 02-25-2010 08:00 AM
rescue boat desing project needed help AUNG SAN TINT Boat Design 17 09-29-2008 12:52 AM
Wooden Boat Rescue Foundation jedclampit Wooden Boat Building and Restoration 2 01-16-2007 08:52 AM
Self Righting Rescue Boat 15Meter for Sale fadly2000 Services & Employment 2 07-01-2001 07:22 PM
