Old 04-27-2008, 07:58 PM
Mdsv16 Mdsv16 is offline
Rep: 10 Posts: 2
Replacing stringers / foam 1980 baja
I recently removed the floor, stringers and foam from my 20ft 1980 Baja. The floor was soft in spots and when I removed it I noticed the stingers were completely rotted. I removed the stringers as well. The fiber glass only covered the bottom half of the stringers. The foam between the stringers was soaked with water. It appears that the foam keeps the water from making it to the back of the boat. Do I need to replace the foam once I replace the stringers or can I leave it out? The foam is only 4 1/2 inches thick at the thickest spot.
Old 04-27-2008, 08:14 PM
dragonjbynight's Avatar
dragonjbynight dragonjbynight is offline
Rep: 70 Posts: 129
yes, all the foam will have to come out before the stringers can be replaced. If its already waterlogged, it won't do anything but rot out the new stringers you put in. Then once it's out will all have to be cleaned and ground down before you can place in your new stringers.
As far as it goes there are tons of threads on stringer replacement in this forum, one of the better ones in my opinion is at: Ski Boat Stringer/Sole Replacement
Missin the waters of maine
Old 04-27-2008, 08:16 PM
Rep: 70 Posts: 129
oops, my apologies...i thought your post stated you were going to leave the foam in...sorry. Errr..In my understanding yes the foam should be replaced, but in that I will refer you to some of the other posts i mentioned as there are many more qualifed posts.
Replacing wood stringers Capt.Bob Fiberglass and Composite Boat Building 2 04-16-2010 11:16 AM
Replacing Wood Stringers With Composite quickredracer8 Fiberglass and Composite Boat Building 6 03-03-2008 09:11 AM
1979 baja -Do i keep the Foam???? 1979baja Boat Design 0 01-08-2008 05:22 PM
Replacing stringers and floors crum731 Fiberglass and Composite Boat Building 4 03-10-2005 05:08 PM
Replacing floor & stringers gbaaron Powerboats 4 06-15-2004 08:26 PM
