| Replacement rudder for Alberg 35 - design and fab considerations Need to come up with a new rudder for my Alberg 35. The old one is made of wood (mahogany) presumably boards bolted to a stainless rudder stock. At some point, it was stiffened by metal plates, through bolted. Pictures can be seen at: http://geocities.com/blainch/picture...ade_rudder.jpg What I would like to do is to make a frame, using either the existing stock or a new one, with welded arms, which will hold a marine ply/fiberglass blade. My uncertainties are: * How much load will this thing see in an offshore environment? I have a hard time imagining that the old setup was adequate, but from what I've heard, it's pretty conventional. * If I make it out of new stock - 316L or Bronze (alloy suggestions welcome)? I am a reasonably competient TIG weldor, but am unsure of the corrosion ramifications - if I zinc the hell out of it, will all of my sins be absolved? * Should I have someone else do it? I have a tentative design on CAD which I can post when I get home (I'm on a business trip right now) Thanks!! Chris |
| whitby boat works which built the albergs is no longer around but alex who worked for them still has a small shop called funny enough whitby boat works just google whitby boat works ontario canada and u should get the number he can be very help full i know for a fact hes done some overhaul on rudders for the 37 |
| alex magnone tel 905 4306766 fax 905 4306449 |
| Thanks... 'preciate it. I'll look him up when I get back home. Chris |
| Alberg 29 rig on a Bayfield 25 | Sonie | Boat Design | 4 | 09-12-2005 06:31 PM |
| j/27 rudder replacement | Hravn | Sailboats | 10 | 04-24-2005 06:09 PM |
| Rudder Design | tspeer | Sailboats | 3 | 03-28-2004 05:38 PM |
| Rudder design question | SeaBird | Boat Design | 19 | 09-25-2003 06:28 PM |
| jackshaft drive considerations | johndezman | Boat Design | 10 | 09-05-2002 06:34 AM |
