Old 03-19-2007, 04:25 PM
Westerly23 Westerly23 is offline
Rep: 10 Posts: 18
Relocating a galley/ thru-hull question
Hello,
I would like to relocate our galley sink aft. The idea location is right above a cockpit drain thru-hull.
Is it acceptable to Y into this thru-hull for the sink drain?
Do you forsee any issues with this?
Thanks.
Old 03-19-2007, 05:15 PM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
Is there any chance of backflow between the two drains? Which drain has the higher originating point, the cockpit? If so, then the p trap on the sink should block any oders or backflow as long as there is no back pressure at the discharge point on the hull.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Old 03-19-2007, 05:23 PM
Rep: 10 Posts: 18
Is there any chance of backflow?
Yes, from the sink into the cockpit, but the thru-hull is much lower than the cockpit, so it should'nt be a problem.
The galley sink is the higher of the two.
I would retain the shut off for the cockpit drain, this should elimitante soapy water from backing up into the cockpit while at the dock.
Old 03-19-2007, 07:18 PM
ted655's Avatar
Rep: 122 Posts: 641
I always thought of the cockpit as having a scupper flap. Interesting that it has a shutoff. One more thing to remember before setting sail, open the cockpit drain.
Fewer hull holes the better, no? I don't see a harm to your idea.
Old 03-20-2007, 06:01 AM
Rep: 700 Posts: 3,207
Bite the bullet and give the sink its own thruhull .
When grease or something plugs the discharge , it can be disconnected at the sink and the hose straightened out.
Then a broom handle can clear the blockage , and the hose returned to the sink drain. No need to touch the seacock if the hose ends above the water line.
FF
Galley Sink ahasiec Boat Design 0 02-08-2005 10:34 PM
Hull question Foiler Boat Design 4 10-19-2004 10:19 AM
Planing hull question TheFisher Boat Design 9 12-05-2003 10:14 AM
Stretching of a hull / relocating the CG 67-LS1 Boatbuilding 26 10-01-2003 07:23 PM
Planing hull question graham Powerboats 1 12-09-2001 05:13 AM
