Old 02-13-2008, 11:26 AM
toda toda is offline
Rep: 10 Posts: 20
Relation between machine power and cargo weight
Have any document or suggestion about relation between machine power and weight of cargo for cargo ship (under 10000T). Could any one give me advice about it. Thanks in advanced.
Old 02-15-2008, 12:52 PM
Kay9 Kay9 is offline
1600T Master
Rep: 279 Posts: 615
huh?
What exactly is it your in need of??????
K9
Old 02-15-2008, 01:41 PM
Jango Jango is offline
Senior Enthusiast
Rep: 63 Posts: 519
For a given Speed, Required Power is proportional to Gross Weight. i.e.
To maintain a given speed, if Gross weight increases by 25%, H P must also increase by 25%
Hope this helps,
Jango
Old 02-15-2008, 01:46 PM
1600T Master
Rep: 279 Posts: 615
Thanks Jango, I couldnt figure what it was he was asking.
K9
Old 02-18-2008, 08:48 AM
Rep: 10 Posts: 20
Thanh you very much for your advice Jango. That 's exactly what I want.
Old 02-18-2008, 10:03 AM
ted655's Avatar
ted655 ted655 is offline
Rep: 122 Posts: 641
shouldn't there be more?
A displacement hull, carrying a gross wt of ??? requires ??? HP, to achieve a speed of ??? Kts sustained.
A formula to get a basic ratio between gross tonnage & HP, THEN the need to increase the load to HP ratio of 1:1?
For every ton, it takes ?? HP, to go ?? Kts.
Ted says: If it has tits, tires, or a transom, there's gonna be issues!
Weight balance. Will it ride better with weight in the rear or dead center? clctrader Boat Design 4 01-24-2008 01:12 AM
Close relation with Casting Çemberci Propulsion 0 05-03-2007 02:12 AM
relation between principal particulars pavel915 Boat Design 9 12-14-2006 11:52 PM
relation between Cb and Cp sujith Boat Design 1 11-19-2005 11:55 AM
Average Human Weight, Safe Excess Weight, &c. Free Pirate Boat Design 12 03-14-2005 02:40 AM
