Old 07-27-2004, 09:29 AM
fcfc
Regulations ?
What are the regulations (codes) that can apply to the scantlings of a 50 ft motorboat (non planning, ie displacement speed) to be built in plywood or strip planking, or even mixed (plywood where developpable, and a radius chine in strip planking, which would also avoid widening plywood sheets)
German lloyd "special craft up to 24 m " (79') apply, but give somewhat like a safe (4" * 4" framing, spaced 18", beams bigger than 4" * 3")
ISO 12215.5 a bit better.
a draft including wood scantlings can be found at http://www.nmma.org/certification/te...hnicalupdates/
Is there something with ABS ?
Motor Pleasure Crafts only for above 79'.
Offshore racing yacht, but with no sail and no ballasted keel.
High Speed Naval Craft, but limited to displacement speed speed.
Thanks.
PS: Design only, not intended to ever be built, unless drowning intentionnal.
PS2: I dont remember who complained about Fexas "midnight lace" boats widening and "heaviering", but there are other light and narrow planning/semi planning boats with moderate power.
http://www.rodgersyachtsales.com/and.html
http://www.nigelirens.demon.co.uk/nid_newproj.htm (RangeBoat)
http://www.bean.fr/imagecatalogue/image/list/30/
http://www.spirityachts.com/sy-power35.htm
Old 07-29-2004, 09:46 AM
fcfc
Regulations.
A bit more.
HSNC code may apply on speed criteria, but has nothing for wood structure.
Is there more recent code than ISO 12215-6:2001 ? this release has only FRP and metal details.
Thanks for answering.
François.
epoxy fuel tanks Boatbuilding 24 08-14-2008 03:36 AM
Steam Engines and regulations Dutch Peter Open Discussion: All Things Boats & Boating 9 10-18-2005 10:15 AM
Regulations covering installation of elec. fuel pump fanefarchris DIY Marinizing 2 04-11-2005 06:24 PM
Gas driven hydraulic generators - regulations? Gilmarine Fiberglass and Composite Boat Building 1 11-01-2004 01:45 PM
Regulations for designing and building your own boat? Boatbuilding 11 10-15-2004 03:45 PM
