Old 04-05-2008, 07:58 PM
captword captword is offline
Rep: 10 Posts: 79
referance material help?
I have two boats on the drawing board. the one boat there are simular boats on the market, to do comparrison too for weight estimation. The other boat that is on the board is an older design but will be built using more modern tachniques. I need to calculate the approximate weight of the boat so i can figure approximate proppeler size and shaft angle. is there a referance book that has weights and densities of wood, fiberglass, composit materials,....
the better composit sites have that data on the web. But is there a book that has this listed? i know that it will not have newer composites in it.
Captword
Old 04-06-2008, 02:10 AM
Pericles's Avatar
Pericles Pericles is offline
Rep: 1117 Posts: 1,648
First purchase must be Gougeon Bros book.
http://www.westsystem.com/
http://www.epoxyworks.com/
Rule of thumb
Epoxy marine ply glass cloth composite. 44lbs per cubic foot
Aluminium. 154lbs " " " IIRC
Pericles
Whilst entitled to your own opinion, you are not entitled to your own facts!
Old 04-06-2008, 03:31 AM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
It would pay to make the shaft angle one that is available from major suppliers, so often I see plans for some dreamed up "shaft angle". The shaft angle is predetermined by the gear box! (often 10deg)
Engines like to have their sumps level so that the oil pump can do its job>
Old 04-06-2008, 09:10 AM
Rep: 10 Posts: 79
I have delt with a florida supplier on several boat remodels. i got to figure prop siz aproximately. After i get a rough propsize i will call and see what he has available so i can adjust the plans if possible. his custom price beets any here n NC. I have worked with enuf boats and had to work around poor design. Settting everything up with the best access possible. My theory is design it how i would want to have to work on it. Not design what looks good from a distance ,but dont try n get to anything below deck. Just tryng to get better details so I can present to a customer.
material help please madmatt Fiberglass and Composite Boat Building 4 12-02-2006 01:33 PM
material help please madmatt Boat Design 2 11-30-2006 07:56 PM
boat material / furniture material bogeyinthekeys Materials 7 09-10-2005 08:29 AM
material bevan Boatbuilding 4 10-15-2004 04:21 AM
Best Material Aquaholic Boatbuilding 1 09-25-2004 05:27 PM
