Old 05-27-2010, 08:25 PM
tunnels tunnels is offline
old one !
Rep: 402 Posts: 1,913
Forgot !!
I am not a believer in mounting floors and engine beds and any major loadings on top of foam cores i have always mount those types of things onto the solid glass so they are completely bonded with at least 120 mm of glass to where the core starts . Low density foams are a reall problem just because the builder want to save a little money or the designer hasnt done his home work or simply dosent know what the outcome can be . It is absolutely scary to see how easy a sheet of glass will peel off a sheet of foam .
Old 05-28-2010, 04:56 PM
Mr. Curious Mr. Curious is offline
Rep: 10 Posts: 3
I would like to take part of the content in ISO 12215. Do I have to by this or ...
My intention is to make a test of a piece of laminate by measuring the force needed to pull this laminate apart in Z-direction. Anyone knows what forces that could be expected in a correct laminate i.e. without delamination?
Old 05-28-2010, 07:31 PM
old one !
The core material you will be using will have had all kinds of tests done anyway so just get there report .
The one you wont find anywhere is laminate peel off foam because its scary , So when a core is damaged the peel rate is over the moon . and it one very strong reason for a cruising hull to break the panel sizes into small areas that are surrounded by glass to glass .
Its also very interesting to look carefully at the test results and do a comparison between Balsa and all the differant foams on the market .
An interesting subject to do with all cores is called CORE SHEAR !!
Dont get me wrong every product has its uses and its place in the scheme of things so its the laminate design engineers job to know and understand what each product will or should be able to do .
20% or failures are caused by the wrong choice of materials and the other 80% of failures are from Bad workman ship !!
No news travels faster than bad news
Old 05-28-2010, 08:00 PM
Landlubber's Avatar
Rep: 1506 Posts: 2,456
Technically the hull can be corrected, economically I doubt it.
The hull/deck joint will be the problem in doing the topsides, and if not done correctly then the integrity of the boat is totally suspect.
I doubt that the "entire hull" has delaminated, the below waterline section is solid glass, not cored as are the topsides.
Old 05-28-2010, 08:01 PM
girvin girvin is offline
Rep: 37 Posts: 73
I agree its a gonner I have done a tone of fiberglass repair work. I only fix delams on deck bc I believe after a hull delams the glass loses its strength. even if injected and compressed back it has flexed too much. when I fix delams on surfboards I have to cut all the glass off that has delamed and replace with new overlaping the good glass by 2 inches. I still tell them it might die a early death. IF you go to swaylocks.com they just did a test with 13 different core mediums.
Old 05-28-2010, 08:03 PM
Rep: 37 Posts: 73
landlubber said it. If it can be fixed its not economical.
Old 05-28-2010, 08:53 PM
Tim Judge Tim Judge is offline
Tim J
Rep: 36 Posts: 57
Delamination
Mr. Curious...is the gel coat blistered and or been repaired where the delamination is found?
Old 05-31-2010, 08:23 AM
powerabout powerabout is offline
Rep: 484 Posts: 1,431
I sailed on a 75' yacht built in the worst yard in Taiwan and in the middle of its layup someone used waxed glass...oops!
Boat builders are not necessarily Boat designers who are not necessarily Engineers who are not builders who are not designers.....
2nd CALL FOR PAPERS - Abstracts due 31st March 2008 CDBarry Press Releases 0 02-04-2008 06:00 AM
How much displacement not due to boat? hiracer Sailboats 16 11-17-2006 03:37 PM
@mail.ru signups banned due to spambots Jeff Forum Questions and Suggestions 1 05-05-2006 09:22 PM
Twin 4.3 leaning due to same rotation props? Shubb Propulsion 17 06-12-2005 09:16 PM
Rudder relocation due to change in proprotation Peter K Boat Design 1 05-01-2003 10:06 PM
