  #46
Old 09-23-2003, 12:16 AM
shu shu is offline
Rep: 10 Posts: 45
You may want to reconsider the daggerboard idea for rowing. The ability to push with one oar and pull with the other can make for excellent manouverability. Eliminating the daggerboard also allows you to come in sideways to a dock, swimstep, etc.
  #47
Old 10-09-2003, 09:40 AM
Just discovered this forum. What computer program are you using for the design of the rowing shell?
  #48
Old 10-09-2003, 05:21 PM
Willallison's Avatar
Rep: 993 Posts: 2,968
The hull was modelled on a very old version of Multisurf LT
Will
Imaginocean Yacht Design
  #49
Old 10-11-2003, 10:53 PM
Stephen Ditmore's Avatar
Rep: 107 Posts: 981
Unless you intend to carry a passenger in the stern I recommend reducing the prismatic to about .53 by making the stern finer. No reason for CB/CG to be more than about 53% aft. I recommend using Michlet to optimise:
www.cyberiad.net/michlet.htm
Having said that, it looks nice, and I'm sure will turn out fine whether you take my advice or not.
  #50
Old 10-12-2003, 05:38 PM
Thanks Stephen - your advice is most welcome....I'll fine up the stern sections a bit. I kept them fairly broad in order to achieve greater stability than is typical of skulls, but I take your point...
The design is in the very early stages still - and I'm in the midst of selling my house - so I mightn't have anywhere to build it soon!
Will
  #51
Old 10-12-2003, 09:24 PM
It should be possible to build your boat at under 30# ( 14kg ??) using wood srtips/cloth/epoxy.
Even at that weight it should stand a lot of abuse.
  #52
Old 05-13-2004, 09:27 AM
mike1 mike1 is offline
Rep: 10 Posts: 35
HI Will,
just come across this forum .
Nice design, I notice that you have updated to some of the suggestions, Have you got any further.
Its now some months into 004 and perhaps you have already finished.
I am also contemplating building a recreational row boat , have gone as far as getting the plans of a 16ft 7 inch whitehall from Mystic sea port, the boat was built about 1870 beam 42 inch with a sliding seat. , definately not a traditional working whitehall. how ever your desing has got me thinking.
I built a cosine wherry ( now stolen ) using strip plank, did'nt suite me I found the cedar tooo springy. and it needed a lot of filling to fair properly am interested about your foam core idea.
Mike
  #53
Old 05-13-2004, 05:59 PM
Hi Mike
I'd like to tell you that construction is well underway - alas my (68 yr old!) mother - for whom the skull was to be built - went out and bought one! Built of GRP and somewhat shorter but heavier than my proposal......
Will
Recreational light whitehall rowboat mike1 Boat Design 7 12-19-2009 10:39 PM
Small Rowing Craft jonwatson Boat Design 1 10-10-2005 07:42 AM
Rowing Skiff kit hannesnetzell Boat Design 6 08-22-2005 03:50 PM
veneer racing shell restoration Kiwi100 Wooden Boat Building and Restoration 7 08-01-2005 05:31 PM
Wooden Rowing shell Rendezvous Don Seales Wooden Boat Building and Restoration 1 08-11-2004 07:58 AM
