Old 07-14-2004, 06:35 AM
Ross Greenbury
Boat building
Originally Posted by donjames
Im looking for advise on the same subject, Ive had boats in the past and have done all the work needed and I am a 20 year carpenter who can' t
wait to to get his feet wet or, not wet, in undertaking a project of this
level of craftsmanship.
don james
Hi Don,
I am at present building a modified "Simpson Ground Effect" and have no experience at all though I do annoy different boat builders I know to learn as much as I can. I still have a long way to go as I am only fitting out the hulls . Some old pictures can be seen on www.homepage.powerup.com.au/~yacht
Regards,
Ross.
Old 07-14-2004, 07:01 PM
TheFisher TheFisher is offline
Registered
Rep: 60 Posts: 83
Originally Posted by Ross Greenbury
Hi Don,
Regards,
Ross.
Hmmm, that link doen't work.
After a little checking, this one does homepage.powerup.com.au/~yacht
Old 07-19-2004, 07:38 PM
regal regal is offline
Rep: 10 Posts: 10
What about aluminum boats, say you can weld aluminum. How hard is the setup, cutting, moving the pieces around, etc?
Old 07-20-2004, 06:04 PM
don james
So it can be done?
Ive checked out your photos and its encourageing to see your progress
I have long sense changed my mind (again), And I'm stuck for good on a power catamaran design. Iv come to grips with what to use as materials
and I believe Im going to settle an a Balsa core /fiberglass/ gel-coat
format simply because of my many years as a carpenter I would feel much
more confident as to my abilities and level of skill. As for fiberglass, Ive done
enough as I say again, confident in that application .So Im going to stick with my strengths first time around and get more educated as I progress.
Looking good! keep it up and keep in touch.
Donjames
Old 07-27-2004, 10:49 AM
Danielsan's Avatar
Danielsan Danielsan is offline
Amateur designer-builder?
Rep: 10 Posts: 229
Hi there,
Also interested in building a boat, I didn't want to get plans of someone else, so I started looking at sketches and found one that I like. 8m50 x 3.1m rescaled to 7m42 for legal reasons in Belgium (more than 7m50 pay 2.500EUR taxes, smaller pay 0.0 taxes)
So took top and side of the design view and started sketching the hull according the existing sketch. The top part is all up to my imagination.
designing will be finished within a few weeks next the building will begin after I analysed the most of the costs foor needed components. I try to reduce the costs to the max using a BMW525TDS car engine(I know the most off the contra's on that topic but I am convinced it will do a good job) maybe some other car parts, classic thru hull drive, classic rudder as a base to develop or to modifie if the boat suites my expectations.
I'm sure it can be done, I hope to spend less than an in bad schape 2nd hand boat.
Wish all the amateur builders goodluck!!!
Daniel Peeters
High Professional building & managing group of super yacht george_moy Services & Employment 1 04-23-2006 04:17 PM
Join in a Co-operative Catamaran Build Venture! Neven Marketplace 0 12-17-2004 02:20 AM
