| RC Boat? WIG, Hydrofoil, tunnel hull, sail, power ... bla blah blah ... so last century! How cool is this? http://www.filecabi.net/v/file/boat-right/wmv Rob |
| Pretty darn cool. Tactic |
| nothing but fun? This sure is fun and surprisingly "in control" on (flat) water and in the air, at high and low speed. Could it be more than a toy? Without engine power/weight ratio's it is hard to tell. One can make a brick fly given ... The HydroFoam looks very much like the Aircat http://www.du-groundeffect.com/index.html . The Aircat is a real WIG. The HydroFoam, however, is probably not balanced as a WIG as I suspect it uses the flip over tendency at speed on the water to point up for (spectacular) vertical lift off. Also there is not one part in the video sequence with sustained near ground flight. Good fun though, Luc |
| Auto engine marinization | DIY Marinizing | 231 | 07-01-2010 08:34 PM | |
| Luhrs T-29 (1995) diesel inboard converted to outboard | Iya | Boat Design | 13 | 03-07-2007 07:48 PM |
| High-Speed Waveless Boat | waveless | Boat Design | 82 | 10-10-2005 08:01 AM |
| Concept Boat Design Contest | Tad | Boat Design | 16 | 09-17-2004 11:13 AM |
| Completely amateur >70cm RC boat | Boat Design | 1 | 09-14-2001 09:36 AM | |
