Old 03-20-2004, 06:41 AM
bevan bevan is offline
Rep: 10 Posts: 16
ratio
how much poylester resin is need for 1 ms for mat? carbon?. can anyone give me a ratio or a amount.
thanks for the help!
Old 03-21-2004, 08:20 AM
Eric Sponberg's Avatar
Rep: 2447 Posts: 1,376
Typically, resin ratios are a function of weight. For example, if the fabric weighs 1 kg, and the resin you put in weighs 1 kg, the total weight is 2 kg, and the resin ratio is 50% by weight. This is a low average for resin ratio in traditional wet layups, but a good average for vacuum bagged laminates. Usually, we deal with fabric ratios rather than resin ratios because the fabric is the strength part of the laminate. Therefore, typical wet layups will have fabric ratios of 30% to 45% (so resin is 70% to 55%), vacuum laminates typically run 45% to 60% (resin 55% to 40%), and the maximum in resin infusion and autoclave is 70% fiber content by weight (so 30% resin) This is the max, and any higher fiber content than this, usually, you don't have enough resin to hold the fiber together--it will be dry in areas.
Hope that helps.
Eric
Eric W. Sponberg
Naval Architect
Sponberg Yacht Design Inc.
St. Augustine, Florida
www.sponbergyachtdesign.com
Mercruiser Alpha Gen II Gear Ratio Help CreoleIII Sterndrives 4 06-01-2006 12:14 AM
gear ratio question captword Boat Design 8 04-19-2005 06:27 AM
WET vs DRY thickness and fiber/resin ratio jfblouin Materials 1 02-14-2005 02:32 PM
help with gear ratio on mercruiser sterndrives Nova II Propulsion 2 12-25-2004 02:33 PM
Volvo 270 gear ratio help... Leon Phelps Powerboats 4 03-09-2004 02:12 PM
