| Rake? Hello everyone I am beginning to build my first boat and am looking over the plans, Ive come to a term "rake"? Can anyone help me and tell me what this means? And maybe any insights into what it means and why it is necessary. Thanks LTW |
| Rake is an angle off he vertical or, in the case of propellers, from the perpendicular to the shaft.
__________________ Gonzo |
| Also the angle of the stem or transom. The term rake is precisely what Gonzo has said.. But it is a term that is context dependant. In boating terms it has nothing to do with the tool used for collecting fallen leaves. |
| "it has nothing to do with the tool used for collecting fallen leaves." Haha that made me smile ... Anyway the context would be on the transom for boat construction. This is just an angle measure on how much to tilt the transom or is it an angle that you cut out of the transom still a little confused. Thanks for the responses thus far though |
| Rake on a transom means how far it leans aft or forward at the top. A traditional transom is "raked" aft, while more modern boats may have a forward raked transom, which is often called a reverse transom (because it's the opposite of traditional). Yes, rake is defined by an angle from a perpendicular, which can be vertical or horizontal. Masts also have rake, usually measured from a perpendicular to the LWL. |
| What about rake at the stem? What are the advantages/disadvantages of having rake at the stem vs. a vertical stem? For example, I notice that the Luxemotor-type Dutch barges have a vertical stem, but Klipper-type Dutch barges have a raked stem. I assume there are considerations that have lead to one or the other that go beyond questions of aesthetics. Does it have something to do with operating in rough vs. smooth water? |
| What about the Bow entry. No rake at all, vertical and sharp, or fair with plenty of rake. |
| if a ship propeller blade doesnt lie perpendicular to shaft axis ,then the it is said to be raked .it helps in giving clearance between the hull and propeller ,hence it helps in the case of vibaration . |
| Mast rake | captjj | Sailboats | 5 | 05-03-2010 04:32 PM |
| a prop's rake | Sindel | Props | 75 | 08-17-2009 03:09 AM |
| Rudder rake as it relates to mast rake and trim. | Pylasteki | Sailboats | 2 | 08-20-2008 10:19 PM |
| Rake on multihulls | cjs | Sailboats | 5 | 03-26-2007 02:51 PM |
| rake of masts | JimHog | Boat Design | 21 | 11-30-2006 02:39 PM |
