Old 06-16-2011, 10:14 AM
frank smith frank smith is offline
Rep: 154 Posts: 672
Radial diagonals ?
Daniel Z. Bombigher used the term radial diagonals in describing the lines of one of his designs . I have not heard this term before . Would someone please explain what this term means .
Thanks , Frank
Old 06-16-2011, 10:33 AM
tom28571 tom28571 is offline
Rep: 1500 Posts: 1,681
I expect he meant the same thing as diagonals. They are radial about a longitudinal axis.
Tom Lathrop
Old 06-16-2011, 05:34 PM
aka Terry Haines
Rep: 1814 Posts: 3,009
There is a discussion in the Wooden Boat Forum archives (2001) that lists uses for diagonals - http://forum.woodenboat.com/archive/...p/t-14114.html
Dances with Turkeys
Old 06-16-2011, 07:19 PM
Rep: 154 Posts: 672
The question is about the term "radial diagonals " . It may have to do with the way in which the diagonals are arranged . I understand the conventional methods that are used for laying out diagonals, and the usage of diagonals . But have never heard the term " radial diagonals ".Maybe it is a French thing.
I understand that diagonals are not used that much today with Cad design being so prevalent . But i use them all the time , and they give me a much better understanding of the form .
Old 06-16-2011, 09:29 PM
Rep: 154 Posts: 672
Well i went back and looked at some of Bombigher's line plans and can see what he is talking about.
Old 06-16-2011, 11:03 PM
Rep: 3125 Posts: 9,398
I suspect what he's trying to say with radial diagonals is they fan out from a single point on the centerline. This isn't as effective as placing each to bisect the stations at close to a right angle as practical, which usually requires you to have multiple starting points from the diagonals.
Old 06-27-2011, 09:27 PM
timothy22 timothy22 is offline
Rep: 76 Posts: 93
Bombigher's line drawing
shows the diagonals emanating from two points in space, at max beam and, well, see for yourselves. The result is not unlike what we see on many older Murray Peterson designs among others. Bombigher just shows us the origin points. I think it may have been intended to help the lofter locate the diagonals on the floor.
Old 06-28-2011, 10:28 AM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Rep: 2037 Posts: 1,719
In most of the larger lofting projects I've done those diagonal origins would be outside the building....not too practical but nice art.
I usually use intersections of the lofting grid to locate diagonals....keep it simple and compact.
In the design shown "Dream", I would rather see a diagonal run more vertically (body plan view) between the two lower diagonals shown. This will be a fair line from the bottom vee surface up through the reverse tuck along the garboard aft.
Old 06-28-2011, 04:07 PM
aka Terry Haines
Unless there is a structural member in the plan eof a diagonal I don't see how it can be of much use for lofting or building, although I did come across this -
"Diagonals informed the shipbuilders of how to arrange the huge wooden components of the ship's ribs on the assembly platforms prior to the connection of the components and subsequent raising of the ribs into place.".
It has also been suggested they help for fairing purposes, clarity, improved precision, a guide to planking curves, as an aid to the designer, or any time the regular orthogonal views fall short of displaying the designer's intent. Hmm - that one covers a lot of ground!
Here's my theory: perhaps they act an aid in visualising the underwater shape of the hull when heeled. Which begs the question, is the use of diagonals unique to sailboat design?
Dances with Turkeys
Old 06-28-2011, 05:12 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Long ago before the internet....before personal computers even......Lines drawings were made by hand, with a pencil on a piece of paper.......It was tedious work making all intersections in the exact same place in all three views of the drawing......so some quick and useful aids were invented......DIAGONALS!.......
You can run in a diagonal after laying out only a couple of sections, this greatly speeds the fairing process.....note how I used them in the powerboat below to fair the forebody into an almost monohedron planing surface aft.....Also note how the diagonal is run through the tumblehome aft where no other lines occur.....
Old 06-28-2011, 05:18 PM
Tad's Avatar
Tad Tad is offline
Yacht Designer
Below is a more usual use of diagonals in a sailing hull....note how the lowest one is used to fair the fillet to the stub keel....the next one up runs upwards through the reverse tuck into the rudder.....also note the highest diagonal ends at the widest point on the transom and fairs the tumblehome into the topsides all the way forward.....
Diagonals on Body Plans welder/fitter Boat Design 6 01-27-2010 01:51 PM
Diagonals on a line plan vinceUK Boat Design 3 01-14-2010 09:53 AM
Radial thrust bearings owene Open Discussion: All Things Boats & Boating 26 12-01-2009 12:40 PM
radial pitch distribution of Ka series shoaib_jaff Propulsion 1 10-02-2006 02:46 PM
Maxsurf: diagonals on flip side DaveB Software 4 01-30-2005 09:58 PM
