Old 09-20-2010, 07:01 AM
jimbo2010 jimbo2010 is offline
Rep: 42 Posts: 32
Radar mast pole Spruce v aluminum
I see these masts go upwards of 8' tall on a 2 3/8" aluminum pole, deck mounted on the sterns of sailboats.
For which they charge exorbitant amounts of money.
I was thinking about making one out of spruce hollow core birdsmouth.
It only needs to be 6' tall and can be supported to the stern pulpit at 24".
If it was made 3" diameter do you think it would be sufficient, for a 12" 2KW dome.
Old 09-21-2010, 11:53 AM
Lurvio's Avatar
Lurvio Lurvio is offline
Mad scientist
Rep: 219 Posts: 267
What is the weight of the radar the pole has to support?
3'' pole sounds plenty strong, but I wouldn't make it hollow (a hole for cables can be made).As I understand it, the bigger the boat, less stress the pole will have from boat movement. You want to make it stronger, laminate the pole from thin (1/2'' to 3/4'') boards.
Lurvio
Hopefully creating something useful, since 1983.
Old 09-21-2010, 12:03 PM
Rep: 42 Posts: 32
It is listed at 11 lbs
Old 09-21-2010, 12:19 PM
Lurvio's Avatar
Mad scientist
Rep: 219 Posts: 267
Yes, a spruce pole will be plenty strong for your use, just make sure it doesn't have big knots or cross grain.
L
Old 09-21-2010, 12:32 PM
alan white's Avatar
Rep: 1211 Posts: 3,325
Make it solid and save many hours of labor. You could also use fir or pine.
Old 09-21-2010, 12:44 PM
Rep: 42 Posts: 32
Since I'll be using hollow core it will be 85% the strength of a solid post.
But since I'm at a a 3" rather than 2.5" it should be ok.
Also the wires go inside.
Old 09-21-2010, 02:31 PM
Lurvio's Avatar
Mad scientist
Rep: 219 Posts: 267
2.5'' would do the job just fine, might flex a fraction more though.
L
Dent in aluminum mast Steve W Boat Design 22 11-15-2009 07:27 PM
Timber to Aluminum mast? sctpc Multihulls 2 08-07-2008 07:27 PM
need sitka spruce for mast? oneuglyboat Marketplace 10 02-12-2006 05:00 PM
Laminated spruce mast survey Sonie Sailboats 4 10-16-2005 09:28 PM
aluminum grade for mast fritzdfk Metal Boat Building 6 08-10-2004 05:16 AM
