Old 07-27-2004, 10:14 AM
Robert Carelli Robert Carelli is offline
questions about wave resistance and form factor
Hey all,
I am currently writing a paper for high school, an extended essay for the IB, and I was if you could help me with a couple of things. I have been looking at the different types of resistance on sailboats, and I can't figure out a couple of things. How is the form factor determined for the viscous pressure resistance, and does anything directly influence the wave resistance of the hull like the wetted surface area of the hull effects the frictional resistance? Well that's all for now.
Thanks,
Robert
Old 07-29-2004, 12:16 PM
Not A Guest Not A Guest is offline
Registered
Rep: 10 Posts: 55
Taylor and Gertler formula.
Old 07-29-2004, 12:34 PM
dougfrolich dougfrolich is offline
Rep: 140 Posts: 560
Length of waterline, speed of vessel, and displacement will directly influence wave making resistance
Old 07-29-2004, 07:54 PM
sorenfdk sorenfdk is offline
Yacht Designer
Rep: 389 Posts: 507
Those are the major contributors, but other factors, such as the prismatic coefficient and the LCB, do play a role, too.
Have a look at "The Bare Hull Resistance of the Delft Systematic Yacht Hull Series" by J.A. Keuning. You can find it here: http://www.sailboat-technology.com under the section "Online Articles".
Best regards and good luck with your paper,
Søren
Old 07-30-2004, 07:31 AM
CDBarry CDBarry is offline
Rep: 279 Posts: 524
What is actually called the "form factor" is a correction used to rescale frictional resistance in model test results, and ca be found in any good naval architecture text.
Solomon Technologies - "Electric Wheel" electric motor propulsion systems lockhughes Hybrid 228 10-12-2011 05:00 PM
Hull speed Mike D Boat Design 33 02-27-2011 02:20 AM
Option One - how big Willallison Option One 43 12-20-2005 06:44 AM
Wetted surface area - approximate formulas Mike D Boat Design 11 08-25-2005 12:00 PM
Wetted surface area II: Cat hulls or Monos? Mike D Boat Design 1 09-26-2002 12:26 AM
