Old 02-14-2006, 05:49 PM
Oyster Oyster is offline
Rep: 90 Posts: 233
In the older wooden work garveys, a hogged sheer was built into the skiffs, since most were operated by tiller steering requiring the person to be in the stern. This was helped a bit by installing the stick steering and cable, allowing you to set a bit foward, helping the runing angle and visibility. . Unless you had a load in them, the nose ran up in the air and late in the afternoon and evening time, its was almost impossible to see anything floating in the water, as just one consideration with the dropped sheerline.
Old 02-15-2006, 11:14 AM
DaveB DaveB is offline
Rep: 11 Posts: 128
reverse sheer -> tanzer 22
I think one of the best examples of this is the tanzer 22... Not my favorite look, but reverse sheer really adds volume to the accommodations:
http://www.lavoile.com/voile/tech/gifs/t-22a.gif
Old 02-16-2006, 02:09 AM
KCook KCook is offline
Rep: 13 Posts: 171
Flush deck maybe. But not the same as a reverse sheer.
Kelly
Old 02-16-2006, 02:40 PM
safewalrus's Avatar
Ancient Marriner
Rep: 659 Posts: 4,759
Guess you could say my moustache has a reverse sheer, you know what walrus's are!
Right that's put everybody off the reverse sheer thing, apart from the guys with the older boats that are just knackered (to much hogging I guess)
Old 02-27-2006, 02:40 PM
Capt. Bill11 Capt. Bill11 is offline
Rep: 10 Posts: 12
Thanks, to most all, that answered.
There was no bet. And I was asking just to confirm what I thought I knew to be true.
As to this:
"Sheeeeze! some people
Call yourself a Captain? what of? a pool team?"
So much for British courtesy.
Old 02-27-2006, 03:15 PM
safewalrus's Avatar
Ancient Marriner
That's Ok Bill I appreciate your frankness - not even a pool team eh!
"I don't suffer from insanity, I'm loving every minute of it!"
"That's what I like about you - nothing!"
Old 02-27-2006, 08:06 PM
Rep: 10 Posts: 12
You're right, not even.
Cheery O, old sport.
Reverse Bows quicksail Boat Design 35 12-10-2008 07:23 PM
Reverse three-pointers Franklin Boat Design 2 07-11-2005 10:14 AM
Fasteners as well as epoxy at sheer/deck joint? bjl_sailor Wooden Boat Building and Restoration 3 05-26-2005 08:47 PM
Prop Efficiency in Reverse phillip Props 3 05-01-2005 11:36 AM
Reverse Engineering Guest Sailboats 9 03-10-2004 02:59 AM
